Gee-Pee Lifetime Member
![](modules/Forums/images/avatars/2753245604985889cd11f6.jpg)
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Sun Sep 21, 2008 8:48 am Post subject: Is my Navman (N20) Dead |
Attached my N20 to its car mounting last night and pressed the 'On' button .....nothing! Battery light showed Green, so assume that is not the problem. Tried turning the power 'Off' then on. still nothing.
Got lost going to a party and arrived about 30 minutes late - but that is another story but just shows how I now rely on this device.
Is my Navman finally dead and gone to the great GPS in the sky
Any suggestions.........apart from contacting Navman
s please _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
TheM Frequent Visitor
Posted: Sun Sep 21, 2008 10:36 pm Post subject: |
Since you can see the charging light your charger is probably fine, and if battery was dead I think N20 would still power up (at least N-series still powers up if connected to a charger when battery is completely drained, I assume the same is true if battery is dead). So probably best you check with Navman... |
Posted: Sun Sep 21, 2008 10:48 pm Post subject: |
TheM wrote: | Since you can see the charging light your charger is probably fine, and if battery was dead I think N20 would still power up (at least N-series still powers up if connected to a charger when battery is completely drained, I assume the same is true if battery is dead). So probably best you check with Navman... |
My thoughts too. Have sent email to Tech Support & look forward to a response when they have got over the weekend. Guess I may have to send the device to them and get them to look at it. :-( Don't hold out much hope though. Will report back when I have something to report. ![Rolling Eyes](modules/Forums/images/smiles/icon_rolleyes.gif) _________________ Gee-Pee
Posted: Mon Sep 22, 2008 5:17 pm Post subject: |
Update....
Got response from Navman this am and I subsequently phoned them. Suggested, deleting back-up folders from device and reinstalling. Whilst I was on the 'phone, the N20, which was attached to the USB cable on my computer suddenly came to life on its own. Before I could tap Accept the agreement, it died again. Later had to go out so stuck the unit on its holder (just for old times sake) and after I drove for about two miles, again it came to life. Gently pressed the 'Accept' option and it re-loaded successfully. Checked the battery state which was 100%. Since then, it has worked without problem.
In the meantime Navman have agreed to send me the wherewithal to send it back to them for repair under warranty (if I can find the receipt) so am now about to ring them and say, 'Thanks, but no thanks'
Must start looking for another device as I suspect there may be something loose in this one. ;-) _________________ Gee-Pee
CaptainDrift Regular Visitor
Posted: Fri Sep 26, 2008 10:56 am Post subject: |
Gee-Pee
Reflash the ROM,
This should resolve the issues.
I will try and dig out my guide |
Posted: Fri Sep 26, 2008 1:51 pm Post subject: |
CaptainDrift wrote: | Gee-Pee
Reflash the ROM,
Thanks and for the PM. As you will see from above post on 22nd, matters have resolved themselves by devine intervention. ;-) _________________ Gee-Pee
