Pocket GPS World :: View topic - GTM21 cigarette power plug broken
netwiz
PostPosted: Sat Aug 30, 2008 10:09 am    Post subject: GTM21 cigarette power plug broken Reply with quote
We eventually figured out that the reason why our NUVI 600 wasn't charging was because the insides had fallen out of the power plug!! I guess there's a screw-on lid, which gives you access to the internal fuse and spring, and somehow they've disappeared. I don't want to have to buy a whole new GTM21, but as the power plug is molded on, the only alternative would be to get replacement innards, and I can't find anyone who does that.
Anyone got any suggestions? I've got a number of other cigarette plugs, and I've had a look to see if I can use those, but I can't.
wiz
PostPosted: Sat Aug 30, 2008 7:45 pm    Post subject: Reply with quote
Hello netwiz
have a look at this from maplin
Car Plug Fuse/LED BV46A £3.29
http://www.maplin.co.uk/Module.aspx?ModuleNo=1054&doy=30m8&criteria=cigarette%20plug
Alan --- aka Wiz.
Iphone 4S 16gb, ios 5 windows 7, CamerAlert, CoPilot & TomTom
netwiz
PostPosted: Sat Aug 30, 2008 9:56 pm    Post subject: Reply with quote
wiz wrote:
Hello netwiz
Thanks, but it's more than just the fuse that's missing from the insides.
wiz
PostPosted: Sun Aug 31, 2008 3:04 pm    Post subject: Reply with quote
just a thought netwiz
its the whole plug not just the fuse and it looked Simula to me.
https://buy.garmin.com/shop/alt-image-lg.do?pID=413&img=productImageLarge
Edit to add Link...
Alan --- aka Wiz.
tynecomp
PostPosted: Mon Sep 01, 2008 9:56 am    Post subject: Re: GTM21 cigarette power plug broken Reply with quote
Ring up Garmin and explain the problem to them; they have been known to be very helpful in similar situations.
Border_Collie
PostPosted: Mon Sep 01, 2008 3:25 pm    Post subject: Reply with quote
Same happened to me a while back. Searched under all the seat, under the car and the around garden path but no luck. Then my wife noticed something in the ciggy socket. There they were, all the bits waiting to be fished back out.
Obviously putting the power plug in and out, and maybe adding an anti clockwise twist, gradually unscrews the end until the 'bits' stay put when you remove the plug. I always insert my plug with a half clockwise twist now.
netwiz
PostPosted: Tue Sep 02, 2008 7:59 am    Post subject: Reply with quote
For the benefit of anyone who has a similar problem, I can answer my own question. I went to a Maplins (like Radio Shack in the US), and bought a very cheap cigarette power plug, that come apart. I took out the spring, fuse and circular clamp that hold it together, and put them in the Nuvi plug, whcih you can prise apart. It all works, and a lot cheaper than buying an entire new recceiver.
PostPosted: Tue Sep 02, 2008 8:33 am    Post subject: Reply with quote
DIY solution are often the best approach well done, but what is the rating of the fuse fitted as it might be too high not offering the correct level of protection - Mike
wiz
PostPosted: Tue Sep 02, 2008 2:05 pm    Post subject: Reply with quote
Maplin That was a good idea wonder where that idea came from.
Posted: Sat Aug 30, 2008 7:45 pm by wiz
Hello netwiz
Car Plug Fuse/LED BV46A £3.29 glad you fixed it without the expense
Alan --- aka Wiz.
philpugh
PostPosted: Tue Sep 02, 2008 3:56 pm    Post subject: Reply with quote
Interesting - never thought about it 'til now but I pull the plug out with my left hand (I'm right handed) and seem to naturally apply a clockwise twist to do this. It's possibly related the the position of the plug relative to the driver position Question
Phil
netwiz
PostPosted: Tue Sep 02, 2008 8:31 pm    Post subject: Reply with quote
The fuse in the original is rated at 3amps. I can't actually read the rating on the replacement (although it works, and I suspect it is 3a). You can however buy a pack of 10 3.14amp fuses (same size) for a trfiling amount, and a box of a few hundred springs for three pounds.
WIZ... thanks for the Maplin suggestion, although when I first read your post, I thought you were suggesting that I could put the plug on the end of the wire, which I couldn't, as it's moulded on.
22.062 (12 Jun 24)
