Pocket GPS World :: View topic - Upgrading GB maps onto a Europe map installation
mikentl
PostPosted: Wed Aug 27, 2008 10:38 am    Post subject: Upgrading GB maps onto a Europe map installation Reply with quote
Hi all
I have a TT 720 with the Europe maps installed on the unit (no card ). Question is, If I install the latest GB only maps, will they replace the GB bits of the Europe map already installed? or will I have to install the new map onto a card?
Many thanks.
Regards Mike
tgold
PostPosted: Wed Aug 27, 2008 1:14 pm    Post subject: Re: Upgrading GB maps onto a Europe map installation Reply with quote
The default will be to install it into the main memory under a different map name and in a different folder so that you will be able to switch between the two.
Tony
mikentl
PostPosted: Wed Aug 27, 2008 1:35 pm    Post subject: Reply with quote
Cheers for that Tony,
To open the thread up a bit. I only have 184mb left in the unit, what can I delete to ensure there is enough room
Regards Mike
EricWB
PostPosted: Wed Aug 27, 2008 3:48 pm    Post subject: Reply with quote
I have very recently installed the latest version of GB & Ireland upon my TT 510 I don't have main memory like you as it uses only an SD card, but the good news is that its 163 Mb as installed, so the new does not overwrite the old but you should just about have enough room for both. I don't know for sure but you could add an SD card to your device and move your old map over to it still leaving a whole lot of room on your internal memory and having access to both maps. I kept both old and new as the old included major roads of western Europe that just might have some sort of use in the future.
The most important thing of all things, is to make sure you have at least one, preferably more backups using Windows not just Home as described elsewhere in this forum then if anything should go wrong you will be able to recover everything back to the way it was.
mikentl
PostPosted: Wed Aug 27, 2008 5:35 pm    Post subject: Reply with quote
Downloaded and installed GB maps with no problems, but TT home now shows my map as being 49 weeks out of date and 32007 mapshare corrections waiting. I tried to update but nothing is shown to download.
Anyone with any ideas
Regards Mike
dhn
PostPosted: Wed Aug 27, 2008 5:49 pm    Post subject: Reply with quote
Yeah....that message most often is caused by wonky TomTom servers acting up again. It's nothing to do with anything on your part.
Try again later... or tomorrow ......... or, Embarassed
mikentl
PostPosted: Wed Aug 27, 2008 6:04 pm    Post subject: Reply with quote
Will try again tomorrow.
Thanks all for your help
Regards Mike
mikentl
PostPosted: Thu Aug 28, 2008 9:19 am    Post subject: Reply with quote
All back to normal now Very Happy
Regards Mike
22.055 (29 May 24)
