Pocket GPS World :: View topic - GPS Not working on Ipaq rz1710
tisque
PostPosted: Tue Aug 26, 2008 12:36 pm    Post subject: GPS Not working on Ipaq rz1710 Reply with quote
I have an Ipaq rz1710 running WM 2003 se. It works fine with TT, GPS set to Com1 and baud 19200. I have now tried to get Memory Map to work on the device. All is good apart from it will not pick up a GPS signal. I have tried selectiing NMEA, but it does not have com1 in the list - only com2 to com9 - any thoughts on how I can get this sorted?
philpugh
PostPosted: Tue Aug 26, 2008 5:26 pm    Post subject: Reply with quote
The usual problem is that people fail to exit the first program using the GPS. Only one application can access the GPS at a time. Make sure you EXIT TT before starting MM. Using the "X" at the top RHS will NOT exit the application. Use the menu option to exit the application.
If you want to run two apps at a time both accessing the GPS, then you will need something like Franson's GPSGate application.
Phil
tisque
PostPosted: Tue Aug 26, 2008 5:38 pm    Post subject: Reply with quote
Sorted... many thanks
22.062 (12 Jun 24)
