Pocket GPS World :: View topic - Not all menu items available in TT6
PostPosted: Thu Aug 07, 2008 1:13 pm    Post subject: Reply with quote
We all know Home is stupid, this is yet another example, you are indeed reading a manual for TTN7 as HelpMe and MapShare were only introduced with TTN7 - Mike
peterc10
PostPosted: Thu Aug 07, 2008 1:34 pm    Post subject: Reply with quote
That indeed appears to be the case.
And if it is all I can say to anybody thinking of parting with their hard earned cash to update to TT7 when it arrives is - don't bother - the few changes are not worth it! Stick to TT6 all the time you are willing to put up with the outdated maps.
Peter
HTC Sensation
Copilot for USA
aj2052
PostPosted: Fri Aug 08, 2008 1:52 am    Post subject: Reply with quote
I concur with Mike, vers 6 doesnt have mapshare and just checked my Navigator 6 which is 6.20 and 675 maps, and none of the items mentioned are shown, my page for Show on Status bar has the following:
1) Remaining Time
2) Remaining Distance
3) Arrival Time
4) Current Time
5) Street Name
6) Speed
All to be checked as required, your manual does not reflect the simple information I have, do TomTom actually produce Manuals, i have only ever seen a single sheet installation guide and thats useless. mine is on asus PDA and on a Mio PDA.
Moto G5s Plus, Sygic 17.4.8
peterc10
PostPosted: Fri Aug 08, 2008 7:47 am    Post subject: Reply with quote
Thanks for your help - yours is the same as mine, which further shows that I have got everything on TT6 and what I was looking at was a TT7 manual - good of TomTom to confuse me like that wasn't it - it probably keeps them crazy Dutch guys amused!
Yes TT have always done manuals - there was usually a shorter paper version (in lots of languages) with the product - its a small square book. A more detailed manual was available on the DVD with the software if you had the DVD version or a seperate CD if you had the SD card version. You could also download an electronic version from TT's website - nowadays you are supposed to use TT Home (2.3 has a button to view it), but as Mike has suggested that is not the best bit of software in the world!
Peter
HTC Sensation
Copilot for USA
MJN
PostPosted: Tue Aug 26, 2008 1:11 pm    Post subject: Reply with quote
Peter,
Whilst it sounds like you're sorted now with regards to the confusion over v6/v7 menu items and what you should and shouldn't have you might wish to be aware that, if memory serves me correctly, there is at least one icon missing from the default v6 menus - 'Backlight Preferences'.
I'm pretty sure this icon last appeared in v5 however the setting/functionality still exists in both v6 and v7 yet the only way to change it is by customising the menu. This can be done as a one-off as the setting is peristant even without the icon present.
I only mention this point as there could well be other icons besides the above that are missing from the default menus.
Mathew
HTC Touch Diamond
peterc10
PostPosted: Wed Aug 27, 2008 5:40 pm    Post subject: Reply with quote
Mathew
thanks for the reply and yes I am sorted for the time being.
According to my TT6 manual the backlight preferences will not be shown if the software senses that your device automatically sets backlight levels, as mine does. That is why it is not there with mine, but presumably will be there if the device did not have this facility.
Peter
HTC Sensation
Copilot for USA
MJN
PostPosted: Wed Aug 27, 2008 9:24 pm    Post subject: Reply with quote
Do you find the backlight turns off (when using TomTom) if set to do so on the device though?
With TT7 on my Diamond I found it to remain lit regardless of my device settings hence I had to add this setting to fix it.
Mathew
HTC Touch Diamond
peterc10
PostPosted: Wed Aug 27, 2008 9:46 pm    Post subject: Reply with quote
Mathew
I have my Touch Diamond set to turn off the device and the backlight if not used for 2 minutes when on battery. However TT obviously overides this because, as you have found, it will not turn off the device or the backlight. I suspect that is because TT is telling the phone that it is still being used, even when it is stationary and nothing is moving.
However I must say that is the way I like things. When I am running TT and driving I always have the Touch Diamond in a powered mount in the car and so there is no question of it turning off, and the battery is always being charged. However I don't want it to turn off the device or backlight if I switch the ignition off for some reason (filling up for example) and thus stop power to the phone.
If I am driving without using TT then I leave my phone switched off and in my pocket and my BT handsfree picks it up anyway.
And if I am using TT without the car I don't want it to switch off automatically while I am using it.
Peter
HTC Sensation
Copilot for USA
MJN
PostPosted: Wed Aug 27, 2008 9:57 pm    Post subject: Reply with quote
That's the beauty of the setting though, you can choose one of three ways for it to behave:
1. Always on - This is the default
2. Use device settings - If you're using the device without auxiliary power then the backlight is going to drain the battery relatively quickly. This setting allows the screen to dim completely yet TomTom to still run in the background. If you've got a turn coming up it will turn the screen back on in plenty of time, give the turn instructions, wait for the turn to go, then eventually turn the screen back off (in accordance with the device timer)
3. Always on only whilst charging - This is my preferred option. If I'm in the car and running of the 12v adapter then battery power isn't an issue hence I'm happy for it to stay on. However, out on my bike I haven't got this luxury yet I want more then a couple of hours satnav use.
Note that the device will never actually turn completely off - TomTom keeps it awake, these settings are only concerned with the backlight itself.
You pays your money etc... but I just thought it worth mentioning not only because I wish TomTom had left the setting in (particularly given they still support the functionality) but also as food for thought as to what other menu items they've dropped...
Mathew
HTC Touch Diamond
peterc10
PostPosted: Wed Aug 27, 2008 11:07 pm    Post subject: Reply with quote
Mathew
sounds interesting - so how did you customise the menu to get these options back?
Peter
HTC Sensation
Copilot for USA
MJN
PostPosted: Thu Aug 28, 2008 10:44 am    Post subject: Reply with quote
Sorry, I meant to provide the link!
As discussed in the thread I only temporarily modified the menu in order to reenable the missing icon to let me set my desired behaviour.
In previous versions I fully customised the menus but now I've decided to stick with the default layout and just get used to it - it is sub-optimal and shows very little HCI consideration but it's one less job for me to do and I'm pretty much used to the standard layout now.
Mathew
HTC Touch Diamond
peterc10
PostPosted: Thu Aug 28, 2008 11:21 am    Post subject: Reply with quote
Mathew
thanks for the link. I am not used to developing this sort of tweak so would be grateful of a bit of advice please.
Firstly where do I put this file in the HTC - what do you mean by "root of the device" in this context? 4GB internal memory or somewhere else.
Secondly how do I make the file - do i just use Word or Notepad or is there some other app I need, and what type of file do I save it as - .doc, .txt or other?
Finally is there a way of making this a permanent option in the my preferences part or somewhere else?
Many thanks
Peter
HTC Sensation
Copilot for USA
PostPosted: Thu Aug 28, 2008 12:08 pm    Post subject: Reply with quote
The "Root" of the device is the location where you will see a number of folders named "GB Map" "voices", "zip" etc, add the SDKRegistry folder to the same area you see the folders mentioned above.
Use Note Pad to make/ Edit the TomTom.mnu file, when it is complete save it to your PC's desktop and it will be"TomTom.txt" right click the file and select re-name, change the file extension from .txt to .mnu - Windows will warn you that this isn't a good idea, just OK through the warning messages (ignore them).
For a more permanent solution you will have to make a full menu text and then include the work around within the menu structure, help is available from web sites such as This One for creating custom menus, there is also a whole raft of menu related information available from Here
Take your time working out which icons you want where and customise the menu to suit what you want from it - Mike
peterc10
PostPosted: Thu Aug 28, 2008 1:04 pm    Post subject: Reply with quote
Mike
again thanks for this info.
My files for maps zip voices etc are on the 4GB internal memory in the HTC, which is equivalent I guess to being on the SD card in other devices - so is that where I put it?
Guess I will probably leave any permanent change until I decide if this temporary fix is good enough! The school of hard knocks has taught me that the motto "if it aint broke don't fix it" is good for me when dealing with complicated things!
Peter
HTC Sensation
Copilot for USA
peterc10
PostPosted: Thu Aug 28, 2008 1:35 pm    Post subject: Reply with quote
Found it by trial and error. You put it in the root of the device not the internal memory and it works. Many thanks Mathew for this little fix. I have kept the file on my pc and will move it back if I need it to change the setting.
By the way mine offered me 4 choices not 3 - the extra one said "only on bike and walking routes". But instead I linked it to power.
And I am surprised that you can still see the screen reasonable well - is the backlight off or just dimmed down to minimum? Mathew - how long can your HTC run with TT on this setting before running out of power?
Peter
HTC Sensation
Copilot for USA
Page 2 of 3
