chelsky Regular Visitor
Posted: Sun Aug 03, 2008 1:00 pm Post subject: TT720 and GPS coordinates |
Hi, I am running software version 8.010 on my tt720. How do I use the gps coordinates. On Archee's website for caravan sites the coordinates are for + or - . On tt it is N or S. If I enter the numbers they are not accepted. In preferencies the units can be set to, d.d , d.m.m or d m s. Would this effect the way it is displayed. If this has already been discussed I would appreciate a link to it. If not, could somebody please explain how to use the coordinates please.
Thank you. David |
Jolly_Roger Occasional Visitor
Posted: Sun Aug 03, 2008 2:05 pm Post subject: |
Choose the one that suits your particular requirements.
D.D is degrees in a decimal format.
D.M.M is degrees but with minutes in decimal.
and D.M.S is the standard degrees minutes and seconds.
The + and - refer to N or E (+)
and W or S (-) |
Posted: Sun Aug 03, 2008 2:14 pm Post subject: |
Hi Jolly Roger, I can only see N and S to enter a coordinate. I am missing something. Thank you. David. The coordinates I am trying to enter only say + or minus. Could you be a bit more explicit. |
carl_the_cobbler Frequent Visitor
Posted: Sun Aug 03, 2008 2:52 pm Post subject: |
Isn't + North and - South (maybe other way around)
and for the other bit
+ is West and - is East or other way around
I reckon + maybe N and E
and - maybe S and W.
But I am not sure, just give it a try
Just checked on the intra web as well, if you look at this page (first one I found) it kind of explains South is - and so is West. North and East are +. Anyway this is the site that kind of shows
http://sps.unavco.org/geoid/
If you can tell us what the co-ordinates are and I'll try it
Carl |
Posted: Sun Aug 03, 2008 3:25 pm Post subject: |
Sorry if I appear thick but the only options I see on TT is N and S. I don't have the option of E and W. The coordinates I am given are (+ - )45.34653/01.51506. Sometimes, when I press OK it changes to E and W, but I obviously don't knoe how to enter a coordinate. Any help how too would be appreciated.
PS. Make it simle please!!! |
Posted: Sun Aug 03, 2008 3:31 pm Post subject: |
That would appear to be decimal degree format:
which you will enter as follows:
N 45.34653 (Press Next)
E 01.51506 (press Next)
if a value is + you enter either N or E
if a value is - you enter either S or W
Mike |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15156 Location: Bradford, West Yorkshire
Posted: Sun Aug 03, 2008 3:42 pm Post subject: |
after entering the north (or south) coordinate, you will then be prompted to enter the east (or west) after pressing next :D
hope that helps!
MaFt |
Posted: Sun Aug 03, 2008 3:45 pm Post subject: |
I am sorry but on my screen I don't have the option of "Next" First of all it comes up as N and S. If I tap the OK button it changes to E and W. You all do it all the time but I have only started to use co-ordinates and I am stuffed!!!!
David |
Anita Pocket GPS Moderator
Posted: Sun Aug 03, 2008 4:21 pm Post subject: |
Follow the instructions in Mike Alder's post carefully, although where he says "Press Next" it should be "Press OK".
The Latitude screen consists of numbers, symbols and the letters N and S.
You need to enter N45.34653 then press OK
The latitude coordinates have now been accepted, and you will then be presented with the Longitude screen, which consists of numbers, symbols and the letters E and W.
You need to enter E01.51506 then press OK
The longitude coordinates are now accepted and you will be presented with a map showing the position you have entered. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Posted: Sun Aug 03, 2008 4:32 pm Post subject: |
The co-ordinates you gave are in France just South of "Bleygeat", hope this is right, between Tulle and Perigueux. |
Posted: Sun Aug 03, 2008 4:39 pm Post subject: |
Thanks Anita, followed your explaination, and it has directed me to my destination. One question, how do you know if you should be entering, N, S,,E or W?
Thank you. David |
Posted: Sun Aug 03, 2008 4:42 pm Post subject: |
You are right carl_the_cobbler, it should be just off the A20!!!!
David |
Posted: Sun Aug 03, 2008 4:58 pm Post subject: |
mikealder wrote: | if a value is + you enter either N or E
if a value is - you enter either S or W |
Latitude is either N (+) or S (-)
Longitude is either E (+) or W (-)
At the top of the screen the device will state which value you have to enter as "Latitude" or "Longitude"
Mike |
Posted: Sun Aug 03, 2008 5:01 pm Post subject: |
chelsky wrote: | Thanks Anita, followed your explaination, and it has directed me to my destination. One question, how do you know if you should be entering, N, S,,E or W?
Thank you. David |
On the first screen (Latitude) if the coordinates you have are a positive number (+ sign or no sign) you enter N, if negative (- sign) you enter S.
On the second screen (Longitude) if the coordinates you have are a positive number (+ sign or no sign) you enter E, if negative (- sign) you enter W. _________________ Anita
UK map 1130.12368
Posted: Sun Aug 03, 2008 5:10 pm Post subject: |
Thanks Mike,Anita and Carl and MaFt. It is a little bit clearer now. Will have to practise. Please bear with me if I return!!!!!!
Regards David
PS Will print off your answere's |
