pallyally Occasional Visitor
Posted: Fri Aug 01, 2008 9:27 pm Post subject: Voices for safety cams |
First of all apologies if in wrong forum. I have downloaded and installed the the uk speed zoned complete cams into my go520.I have also downloaded the voice files(Liz) speedzoned zip onto my desktop. Now this is where my ageing brain is beginning to fade. Do I unzip and copy the files straight into the map folder as I,ve done with the cams or what?? I can see the speed cams ok on my device but as yet I,ve set no distance up yet.I have read the stickies till I,m going mental. Could anyone please put me (and my ageing brain) at ease with any easy to understand instructions ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) |
Posted: Fri Aug 01, 2008 9:49 pm Post subject: |
Unzip the voice pack download and copy the files to your map folder (as you suspected was required).
Then go to Change Preferences/ Manage POI/ Warn When Near POI and select the first camera listed (if you type "PO" without the "") it will simplift the list to just the cameras and save you some time while looking through the list).
Set a distance you are happy with, 30MPH = 300 yards, 50MPH = 500 yards, 70MPH = 700 yards, you can guess the others I bet.
Next it will ask you "Is the warning sound you want to use" - it won't play anything, you wont hear anything, simply answer "YES" to the question.
Set the Warn only if POI on Route option if you want to, remember you will only get a warning if you have a route planned with this option selected, leaving it unchecked will give you warnings all the time but the cameras might be on adjacent roads.
Repeat the above setup for each camera category you have installed to the device, this will take some time, but once configured it is done. For updates simply copy the ov2 files to the device, there is no need to setup the unit again following an update - Mike |
Posted: Sat Aug 02, 2008 8:56 am Post subject: |
Thanks for the reply. I have done as suggested and so far so good.I have done the uk gatso 20/30/40/50 etc ok and uk mobile ok But when setting up the uk pmobile and redlight I get the warn when near sign then sound effect then it just offers the normal bell/beep symbols. When trying to set the the Specs up it asks about yardage/press ok /sound effect but then loops back to the yardage page It keeps doing this all the time. Please head me in the right direction as I,m getting a bit frustrated again
Thanks |
Darren Frequent Visitor
Posted: Sat Aug 02, 2008 9:09 am Post subject: |
Soft reset, this will resolve the lopping issue. _________________ Darren Griffin |
Posted: Sat Aug 02, 2008 10:13 am Post subject: |
Thanks Darren. Done that but still as quoted above. Do I get any voices on the pmobile and specs ones? |
Posted: Sat Aug 02, 2008 10:21 am Post subject: |
You should get sound files for the Specs camera in the Liz Speed Zoned pack, I don't think the pMobiles are included though - have you re-named any files at all, either POI related or ogg? - Mike |
Posted: Sat Aug 02, 2008 10:35 am Post subject: |
All as I,ve done is downloaded the speed zoned zip and the Liz files under her photo with the 70 logo on and followed the instructions .As far as renaming files I haven,t the foggiest I don,t know what an ogg file means in any case
Thanks for being patient |
Posted: Sat Aug 02, 2008 10:57 am Post subject: |
Ok here,s a follow on. I,ve just downloade Liz(pmobile) which I missed in the list and set them up ok and tried them in the red light and the uk specs ones and they have all gone through and accecpted.So I presume they work ok. So thanks to all that helped me. Phew |
