Pocket GPS World :: View topic - 920 wont turn on!!
920 wont turn on!!
a444lad
PostPosted: Fri Jul 18, 2008 10:41 am    Post subject: 920 wont turn on!! Reply with quote
I just plugged my tomtom into the comp to do the updates and it did it, then after i unplugged it it wont turn on.
When i plug it into the comp now i keep getting a message saying "USB device not recognised" but the green light stays on at the bottom right to say its connected. I just tried plugging it into another comp and the same message comes up on that 1 about the device not being recognised.
I also tried plugging it in to the car charger but it still wont turn on.
Can anyone help please.
PostPosted: Fri Jul 18, 2008 10:48 am    Post subject: Reply with quote
First... have you tried a reset with a paperclip in the hole on the bottom?
Second.... here are a batch of things you can try, described on the TomTom website HERE
Third... try the "search" feature here to see if anyone else has had a similar situation.
If none of those work, we'll have another think...
trevor.dowle
PostPosted: Mon Jul 21, 2008 1:08 pm    Post subject: Reply with quote
I found the paper clip reset solution worked with my 730, as the first time I connected it, I found it wouldn't switch on after disconnecting from the docking station.
I have also found that after undocking, the power on switch needs to be depressed for about 5-6 seconds in order to power up. After that it's OK.
Regards
Trev Dowle
TomTom 730 T
22.055 (29 May 24)
