Pocket GPS World :: View topic - Fix allows d/l of map for 'cannot be installed..." mess
AshleySear
PostPosted: Wed Jul 16, 2008 12:27 pm    Post subject: Fix allows d/l of map for 'cannot be installed..." mess Reply with quote
Copied from my message in the navigator forum:
Currently TomTome Home does not allow you to download maps proper to a PNA onto a PDA reporting 'this cannot be installed to your device'.This can mean you have purchased a map you then cannot download.
This is a link to a post with a patch for TomTom Home 2.3 PNA which allows you to download purchased maps from the TomTom shop onto a PDA running TomTom 7.
It may work for the PNAs suffering the same problem.
After downloading you must install the map manually
It is not my work or idea and appears to work on my Tytn II.
http://forum.xda-developers.com/showthread.php?t=401679&page=55
post #541 refers
Hope this helps someone.
Ashley
PostPosted: Wed Jul 16, 2008 12:51 pm    Post subject: Reply with quote
From that link:
TomTom Home won't be able to install any maps you bought, but it will download them to your PC.
But I think the problem on PNAs is that you CAN download the map, but once it is installed on the TomTom the activation/protection will not allow it to be used?
AshleySear
PostPosted: Wed Jul 16, 2008 1:04 pm    Post subject: Reply with quote
I don'y use a PNA myself so you may be correct.
On the PDA you d/l the map and it creates several files on the PC
*.zip
*.cab
What I believe you need to do is:
1.On The PC unzip *.zip to a directory name ie:Western_Europe
2.On the PC open *.cab with winzip and extract the *.dct file to the previously created directory (step 1)
3.On the PC copy the new directory to the SD card or copy it to the PNA
As I say I cannot test or try this as I don't have a PNA,but it may be of help....alternatively the PNAs are so different from the PDA that this is a load of rubbish and I'm talking nonsense
Ashley
22.055 (29 May 24)
