Pocket GPS World :: View topic - lost maps?
lost maps?
andyvolvo
PostPosted: Sun Jul 13, 2008 7:33 pm    Post subject: lost maps? Reply with quote
please help me i have just loaded speedcamara database on to my garmin c510t it now says "no detailed maps found that support routing the streetpiolet can notnot be used without them" any ideas what to do
BigPerk
PostPosted: Mon Jul 14, 2008 1:53 am    Post subject: Reply with quote
Try a reset (soft/hard) of the unit. Or,
If you made a backup of your satnav files before this, now's probably the time to reload them and start again! (If you haven't, make sure you ALWAYS do in future when loading any software/data.) Or,
If you have recently purchased this unit, see if the retailer can reset the software. I got this message/problem (not because of the camera database) a long time ago, and it didn't happen again afterwards. Or,
Contact the Garmin help desk.
You may get better advice, but this might do for a start. You shouldn't have got this if you loaded the files as instructed - can you say more precisely what steps you went through and any messages you got?
(Navigon 70 Live, Nuvi 360)
andyvolvo
PostPosted: Mon Jul 14, 2008 5:49 pm    Post subject: Reply with quote
thanks bigperk i have tried to reset still no joy.i tried to load backup still no good. i have phoned halfords as unit is 10 months old they said bring back in they will phone garmin ps this is 2nd unit to do this maybe thier is a fault on them 1st 1 locked up this computer page still on would not turn off or reset so thanks again. anyone else had problems with streetpiolt c510?
BigPerk
PostPosted: Mon Jul 14, 2008 6:56 pm    Post subject: Reply with quote
Shame - I would suspect a fault. When I had a C510 I never had trouble with loading the camera database. Was the fault on your previous unit the same and also after downloading the database?
As a matter of interest, had you loaded the database successfully onto this unit before? What format did you choose when downloading it (eg consolidated, by type) and how many other sorts of POIs had your unit got on it? There may be a capacity limit which can screw up a Garmin unit (certainly is on an i3). Also Did you use ASH10's Camera Utility, or do a direct download from PGPSW? If you can give more details, someone on the forum who knows more about database downloading may be able to help you.
But certainly get Halfords to help while they still will!
nuvi350za
PostPosted: Tue Jul 15, 2008 11:05 am    Post subject: Reply with quote
Thanks a lot for this post .
My GPS (Garmin Nuvi 350) is not a problem.
Very Happy
BigPerk
PostPosted: Tue Jul 15, 2008 11:44 am    Post subject: Reply with quote
I've found a thread which suggests you certainly can overload a C510 with POIs:
POI download limit on streetpilot C310
There are references in some others, also with a couple of suggestions of how to recover and reduce number of POIs.
Garmin Testing - THE RESULTS
A search could throw up more info if you want
(There is also a file which should be on the unit, containing the Unlock code. Losing that also gives rise to the message you got as well. So if you are still searching (!) after trying other routes, you ought to be able to ferret out the references on this site. I think it's maybe somewhere to do with a discussion on Text-To-Speech voices on Garmin, possibly connected with the C510, but I can't be sure now.)
