Pocket GPS World :: View topic - Problems changing road speed
uffe73
PostPosted: Sun Jun 08, 2008 9:35 am    Post subject: Problems changing road speed Reply with quote
Ok, maybe this has been discussed already, but I was unable to find it.
Has anyone been able to use the new MapShare feature for changing road speed data successfully? The implementation of this feature appears strange to me as I cannot select only one specific stretch of the road where the change shall be applied. The unit automatically selects a much too long stretch of the road and doesn't let me deselect the parts that shall not be affected. The problem only seems to appear on a motorway though. If I change road speed on local roads in my home area it seems to be working.
Anyone got a clue about this? Actually, I would say that the implementation of the "change road speed" feature in the 7.481 version of the software was better, except that the information wasn't immediately applied to the map.
/Ulf
TomTom GO720T: App ver 8.351(9982/090518), OS:315187, GPS v1.20, Boot 5.5120
TT RDS-TMC: 4V00.013
Maps: Scandinavia v840.2562, Western_Europe v715.1703
Garmin GPSMap 60CSx (SW ver. 3.70)
PostPosted: Sun Jun 08, 2008 9:47 am    Post subject: Reply with quote
Have a read through the first two posts in This Thread, the first post shows a simple change, the second explains how to alter a small section of a much larger road. There are problems with using this in the UK, but in Sweeden you use KPH so it will work fine - Mike
Tim Buxton
PostPosted: Sun Jun 08, 2008 9:51 am    Post subject: Reply with quote
What device, software and map are you using? When you make your selection is there an option to 'Edit' in the bottom left hand corner?
It seems to me that the roads can only be selected to or from junctions with other roads, as opposed to what is really required, which is point-to-point selection. Obviously there are far fewer junctions on motorways so the selection points are also few and far between.
This has been mentioned to TomTom on more than one occasion.
Edited to add: Your sig doesn't show in the Reply window. I see your device info now. Embarassed
Tim
uffe73
PostPosted: Sun Jun 08, 2008 10:06 am    Post subject: Reply with quote
Ok, thanks for that clarification. That explains why it behaves this way. With this implementation the feature becomes quite useless since temporary changes of road speeds between road junctions are common, at least in Sweden.
/Ulf
LB-Greg
PostPosted: Sun Jun 08, 2008 9:27 pm    Post subject: Reply with quote
Mike - what problems are these? I've notice that since updating to 8.010 on a 720 that some maximum speeds are showing 29/39/49 not 30/40/50mph Confused
Calomax
PostPosted: Sun Jun 08, 2008 9:51 pm    Post subject: Reply with quote
They do appear to all show 1 mph lower than what you set. And you can't set them 1 mph higher to allow for that because it will only accept increments of 5 mph/kph
TT Go Essential
GerryC
PostPosted: Mon Jun 09, 2008 8:01 pm    Post subject: Reply with quote
As this happens on some (but not all) speeds, it's suspected that mapshare updates may be recorded in km/h and that this is a rounding error between entering the data in mph, converting to km/h then converting this back to display on screen.
Another bit of careful testing by TomTom. Embarassed
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
Calomax
PostPosted: Mon Jun 09, 2008 9:50 pm    Post subject: Reply with quote
That looks right. I changed to kilometres & tried to set 63, which should be 40mph. It defaulted to 65 kph but, when I changed back to miles & ran a demo, it come up as 40mph and not 39mph as it did when I tried to set it in miles.
TT Go Essential
LB-Greg
PostPosted: Mon Jun 09, 2008 10:57 pm    Post subject: Reply with quote
Hi Calomax
this approach works for 40mph, but not 30 or 50mph.
50kph gives 31mph & 80kph gives 49mph (OK so it's only 1 mph but it's still wrong).
Strawbs
PostPosted: Mon Jun 16, 2008 1:47 am    Post subject: Reply with quote
Any way to clear the data once entered? I tried a restore to before I updated the speed, but it's still reporting 29mph on my road.
a minor, but annoying error.
iPhone 12 Pro
GPS_fan
PostPosted: Mon Jun 16, 2008 5:44 am    Post subject: Reply with quote
Not only this, but my 720 then randomly selects which corrections it might use - read here
Andy
Strawbs
PostPosted: Mon Jun 16, 2008 1:40 pm    Post subject: Reply with quote
GPS_fan wrote:
Not only this, but my 720 then randomly selects which corrections it might use - ...
Right! I just found that by electing to "Remove Corrections" in Home\Tools\Mapshare! I have removed the 29mph speed limit I had set on my road and other map corrections I made myself! but strangely, the corrections from others still remain. Confused
Just have to backup & re-enter the local corrections, then I'm all set again.
HTH.
iPhone 12 Pro
Tim Buxton
PostPosted: Mon Jun 16, 2008 2:06 pm    Post subject: Reply with quote
That's because you can choose to remove your own corrections, those made byTomTom/others, or both lots.
Tim
Strawbs
PostPosted: Mon Jun 16, 2008 2:18 pm    Post subject: Reply with quote
Aha! Not so strange afterall then. Embarassed
iPhone 12 Pro
PostPosted: Mon Jun 16, 2008 3:32 pm    Post subject: Reply with quote
But still no way to remove ONE correction (even if it was just to remove the LAST correction). Make one mistake and you have to lose the lot (unless you'vew got good backups of course!)
23.075 (31 Jul 25)
