Joined: Jun 27, 2006 Posts: 22 Location: Dagenham Essex
Posted: Tue Jun 10, 2008 6:02 pm Post subject: 930T poor battery life
I've had my 930t now for 3 weeks and the battery will not last for more than 75 minutes .
When the battery indicator drops below half, the voice guidance starts cutting out unless i turn it down so low i can hardly hear it.
Also when the batt indicator reaches 1/4 the unit switches off.
So now after about 30-40mins i have to connect the charger so i can keep the volume high without affecting the performance
The bluetooth function is switched off, so its not that killing the power.
My previous TT910 battery lasted up to 2.5 hours which id be more than happy with on the 930.
Overall im happy with the 930 but this crap battery performance is driving me up the wall, how on earth can TT quote 5hrs
Posted: Tue Jun 10, 2008 6:22 pm Post subject:
You·can increase duration by fully using the power save options while the device is in use but I much doubt anyone uses these to be honest.
The device is supplied with a car charger cable that is supposed to be used to power/ charge the unit while in use - Mike
Posted: Tue Jun 10, 2008 7:45 pm Post subject:
But surely I shouldn't have to use the car charger after 30-40mins from a full charge so i can keep the volume up high without it distorting due to low power.
Why put a battery in the first place! if its only good for just over an hour. And then claim up to 5hrs use, which going by mine would never be possible, even changing the battery saving settings , probably wouldn't make difference. And as you say who would use them anyway.
Its just that on my 910 my battery used to last 2hrs even with my phone conected
Surely i must have a dud battery.
Come on other 930 owners, what's your battery life like?
It's honestly going to be hard to answer for you mate...
Because just as Mike says, so few of us use it that way... It IS designed to be used on power, irrespective of it containing a battery.
Indeed, I used to use my 720 that way, on battery, at first, thinking I was doing the right thing, by letting it fully drain and thus discharge, and then topping up fully.
But then it was explained to me, that each battery is good for maybe a 1000 full charges. And if you drain it part way, that would be half of one of those 1000 full top ups I indicated.
So realising that, I decided I NEVER want to use my device on battery, UNLESS I can ONLY run it on battery.
In other words, why waste them 1000 top-ups using it on battery, when I can be using it plugged in - thus saving those 1000 top-ups for when I CAN'T plug it in for some reason.
So Mike's right - run it plugged in mate. Contrary to what you might feel, with it containing a battery, that's NOT how it is designed to be used now.
Picture the latest mobile phones, that USUALLY run on battery. Now that they contain a gps module in the latest, you are SPECIFICALLY told to always POWER it when using the gps for in car navigation.
True Sat-nav's are now no different, given their larger screens, FM output, bigger internal speakers etc etc. AND of course a slimming down in size, from the older devices with BIGGER batteries, that you allude to.
I too though, was surprised how little time I got out of my old 720 on battery.
But to be fair, yes, your mileage, on battery, with No FM Out, BT turned off, etc etc, sounds still poorer yet.
Posted: Tue Jun 10, 2008 9:25 pm Post subject:
Select Internal Speaker or Line Out for both the spoken navigation voice and Music in Change Preferences/ Speaker Preferences anf the FM Tx will be turned off - Mike
Posted: Tue Jun 10, 2008 9:55 pm Post subject:
shadamehr wrote:
730 user, but close...
thanks shadamehr for your reply
Erm, my posts have a habit of, in my words, forming a detailed and comprehensive explanation.
Or in other people's words, being "too long".
You pays your money, you takes your pick, I reckon
So the joke runs that...
1) You posted a reply, quoting me, but snipping out the wording, to save space.
2) This made it look like I had not said anything.
3) This made one of regs on here, respond with "I find that hard to believe".
4) And then Andy saw the funny side of it too.
Suffice to say mate, this a canny place, very knowledgeable, and with a lot of people happy to help.
But GOD help you if you use more than 125 words in a reply - you'll never hear the end of it ever. It is rather, er, biased toward short answers, sadly, much to it's discredit, compared to other forum and of other topics too - they fail to realise that given the font used on phpBB based boards, compared to more modern and easy on the eye phpNuke etc, and the fixed width, then posts automatically seem much longer than anywhere else right from the off - so add my 'detailed' nature to the mix, and it always seems worse than it really is.
I also use paragragh spacing (like this gap now) to make it easier on the eye and for the reader, but then get told this makes it too long on the screen itself. Doh. Catch 22.
But in closing, let me just make clear, I saw the funny side to this too, and congratulate those concerend on a piece of clever light-heartedness, for sure.
And come on folks, "why use one word, when a thousand will suffice", has always been my maxim, as well you all know!
