joe0543 Occasional Visitor
Posted: Fri May 30, 2008 3:04 pm Post subject: camera database |
Having downloaded and installed the camera database onto my Zumo 550 I gave it a test run to check it out < I found that the only warnings I am getting are speed restriction zones ( ie, 70mph zone ect.)There is no indication of speed cameras/types as shown when I activate the built in garmin database,
Suggestion please
regards
joe |
Darren Frequent Visitor
Posted: Fri May 30, 2008 5:07 pm Post subject: |
Hi Joe, I'm not that familiar with Garmin but I do know they only trigger if you exceed the limit as you approach a camera? _________________ Darren Griffin |
Posted: Fri May 30, 2008 11:26 pm Post subject: |
Hi Darren
Even when exceeding the speed limit when approaching a known fixed camera site, my zumo only said (70mph zone ahead) ect .I think I will switch off the pocket gps info and try the Garmin data base to see what difference there is
joe |
Posted: Sat May 31, 2008 8:59 am Post subject: |
How did you install the database to the Zumo?
Do the camera appear in your Custom POIs? They should be listed under Where To?, Extras, Custom POIs
Have you got Proximity Alerts on? Spanner, Proximity Points, Proximity Alerts |
Posted: Sat May 31, 2008 9:55 am Post subject: |
Joe, something is not right here, if you can answer Paul's questions we can get the bottom of this for you! _________________ Darren Griffin |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15155 Location: Bradford, West Yorkshire
Posted: Sun Jun 01, 2008 1:31 am Post subject: |
hi joe,
just checked your download history and you've been getting the gpx files.
you will be better off going for: Garmin POILoader / Consolidated by Type
then you will get icons per camera type as well as specific speed warnings
MaFt |
Posted: Fri Jun 06, 2008 12:13 pm Post subject: spedd cams |
Sorry to be late in getting back to you, Thanks for the info, I will check and see what comes up,
ps I am new to the system and not up to speed with it yet,
regards
joe |
Posted: Fri Jun 06, 2008 6:53 pm Post subject: |
not a problem! everyone starts somewhere! also, cos we're all nosey here please do let us know how you get on!
MaFt |
Posted: Sat Jun 07, 2008 9:48 pm Post subject: SPEED CAMS |
hI
Followed your advice, removed the previous download ind installed the new info as advised ,had a run out today and things seem to be working okay, ( speed cams now showing )When I come to check for updates, do I follow the same procedure,?
regards
Joe |
Posted: Sat Jun 07, 2008 10:54 pm Post subject: |
Yes _________________ Darren Griffin |
Posted: Mon Jun 09, 2008 10:05 am Post subject: |
Yes, BUT just get the poiloader version this time! there's no need to download the gpx file then install and remove and then get the poiloader ones
just the poiuloader csv files
MaFt |
Posted: Thu Jun 12, 2008 8:57 am Post subject: downloads |
Thanks very much chaps.
regards
joe |
