Pocket GPS World :: View topic - x30 - Compass Reversed
SpeedCam
PostPosted: Tue May 20, 2008 8:24 pm    Post subject: x30 - Compass Reversed Reply with quote
Has any other user of the x30 range noticed the compass is reversed. Whilst travelling from London to Bristol today the compass was pointing East, and on the return pointed east. North & south seem to be OK.
dhn
PostPosted: Tue May 20, 2008 9:00 pm    Post subject: Re: x30 - Compass Reversed Reply with quote
I thought that the x30 models ONLY had the compass pointing north ... with no way to adjust that as x20 models could.
PaulB2005
PostPosted: Tue May 20, 2008 9:01 pm    Post subject: Reply with quote
I've seen this mentioned on another forum yesterday, so it appears you're not the only one... I'll see if i can find it again....
PostPosted: Tue May 20, 2008 9:16 pm    Post subject: Reply with quote
The compass will only point North on x30 devices there is no other option available for selection, to be honest the indicator is that small I turned it off as it is as much use as a chocolate teapot compared to what we have used before - Mike
SpeedCam
PostPosted: Thu May 22, 2008 1:44 pm    Post subject: Reply with quote
Yes agree that it's small and can only point north, but when travelling east it points west, and travelling west points east, north & south are OK.
PaulB2005
PostPosted: Thu May 22, 2008 2:19 pm    Post subject: Reply with quote
So when you are travelling East it's pointing to the left or down? 9 or 6 o'clock?
Again when you are travelling West it's pointing to the right or down? 3 or 6 o'clock?
Screen shots?
SpeedCam
PostPosted: Thu May 22, 2008 9:52 pm    Post subject: Reply with quote
When travelling east it points to the right, 9Oclock, and when travelling west it point right 3Oclock
GerryC
PostPosted: Thu May 22, 2008 10:06 pm    Post subject: Reply with quote
That sounds right for it pointing North. Imagine the x30 lying on it's back and you looking down on it like an old magnetic compass. When travelling East, North is over your left shoulder (9 o'clock) and vice versa.
It's not showing your direction of travel which would match what you have been describing re East/West swapped over.
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
PaulB2005
right, 9Oclock
Can you have another go at that?? Left is 9 oclock, right is 3 oclock
Well that's right (correct) When travelling West, North is to your right (3 oclock)
SpeedCam
PostPosted: Fri May 23, 2008 9:40 am    Post subject: Reply with quote
PaulB2005 wrote:
right, 9Oclock
Razz Ahhh well spotted I was wondering how long it would take some one to spot my mistake.... it should read:
When travelling east it points to the left, 9Oclock, and when travelling west it point right 3Oclock
PaulB2005
PostPosted: Fri May 23, 2008 9:49 am    Post subject: Reply with quote
What's wrong with that then?
When travelling East, North is to your left. Think about driving from Bristol to London.
When travelling West, North is to your right. Think about driving from London to Bristol.
I think this is the same "problem" that someone else decsribed.....
PaulB2005
PostPosted: Fri May 23, 2008 10:01 am    Post subject: Reply with quote
Re-reading the thread it appears you have got how the compass works slightly confused. You say "it's small and can only point north" but then you seem to be expecting it to point East when you are travelling East and point West when you are travelling West. It doesn't as you yourself said it always points to North.
So when you are travelling East, North is to your Left so the compass will point to the 9 o'clock position.
So when you are travelling West, North is to your Right so the compass will point to the 3 o'clock position.
It's your comment that "north & south are OK." that's shows what's confusing things. When travelling North, North is in front of you, so the needle points to 12 o'clock and when travelling South it points down-wards. BUT the reason for it pointing down-wards is not because you are travelling South but because North is behind you. It seems you are expecting the needle to point to the left when travelling West and the right when travelling East.It won't because it's not indicating the direction you are travelling in but, as you yourself said, it always points to North.
22.055 (29 May 24)
