Beefheart Occasional Visitor
Posted: Sun May 18, 2008 2:49 pm Post subject: POI capture - Nuvi 250W |
Is it possible to capture or mark a Point of Interest whilst driving?If so, how?
Any tips, please.
Thanks,
John |
Posted: Sun May 18, 2008 7:35 pm Post subject: |
Touch the screen and hold your finger there for a second or so and it'll record a favourite called 001. Then next will be called 002 etc Then when you can a chance you can rename the favourites.
Probably not best to do any of this if you are driving..... |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15155 Location: Bradford, West Yorkshire
Posted: Mon May 19, 2008 8:18 am Post subject: |
or, tap the screen (without holding it down) then it will show a 2d map with a 'dot' where you pressed the screen. pull over and fine tune the position on the map then do the naming and saving.
obviously this method needs you to be able to pull over!! if not then use paul's above!
MaFt |
Posted: Mon May 19, 2008 9:07 am Post subject: |
I think MaFts method is better because i can only make my method work by accident when i don't want it to! |
