jlw Frequent Visitor
Joined: May 10, 2004 Posts: 402 Location: South Sweden
Posted: Thu May 13, 2004 1:33 am Post subject: What Fortuna Clip-On combination are you using? |
Like the topic describes: What Fortuna Clip-On combination are you using?
I have toughts of buying an ipaq 2210 with tomtom navigator 3 and fortuna clip-on as a gps receiver. Will it work without any problem at all?
What is the most usual problem with the clip-on and with the ipaq 2210 ?
Goodnight guys!!
// A tired Viking from Sweden
barryp Occasional Visitor
Joined: 25/06/2003 20:55:47 Posts: 29 Location: United Kingdom
Posted: Thu May 13, 2004 5:47 am Post subject: |
I am using a iPAQ 5550, Fortuna Clip on, Tom Tom 3 and Memory Map, so far no problems, except trying to convince Tom Tom from trying to use the GPS connection all the time, stopping Memory Map from using it, but I solved that thanks to the Tom Tom forum here
Barry |
Razer Regular Visitor
Posted: Thu May 13, 2004 10:54 am Post subject: |
4150 and clip-on, had it for just over a week now. No problems so far (using tomtom) |
Posted: Thu May 13, 2004 12:29 pm Post subject: |
barryp wrote: | I am using a iPAQ 5550, Fortuna Clip on, Tom Tom 3 and Memory Map, so far no problems, except trying to convince Tom Tom from trying to use the GPS connection all the time, stopping Memory Map from using it, but I solved that thanks to the Tom Tom forum here
Barry |
Do the ipaq loose the bluetooth connection? How long time? |
Posted: Thu May 13, 2004 1:10 pm Post subject: |
As soon as you start Memory Map it can not open the Bluetooth COM port as the TomTom driver uses it even though TomTom is not actually running.
As I indicated this can be solved by uninstalling TomTom GPS driver, which does not actually stop you from using the program and it stops it from hogging the COM Port unless TomTom is actually running.
Not very pretty but it works.
Barry |
Posted: Thu May 13, 2004 1:19 pm Post subject: |
barryp wrote: | As soon as you start Memory Map it can not open the Bluetooth COM port as the TomTom driver uses it even though TomTom is not actually running.
Barry |
what is memory map? |
