Pocket GPS World :: View topic - IGO 2006 problems loading to PDA
chelseafan
PostPosted: Wed Apr 23, 2008 11:46 am    Post subject: IGO 2006 problems loading to PDA Reply with quote
I am having problems getting autorun from my SD card with IGo2006 onto my PDa running windoes ce
I loaded up to the sd card with IGo add to the slot but no autorunning although there is an autorun file present.
I figured that the programme would auto install onto the PDA as per Tomtom.
Every time i trying and run the autoinstall file it flags up "application not present"
How can I force the install or do I need to tweak something.
thanks in advance
Border_Collie
PostPosted: Wed Apr 23, 2008 1:42 pm    Post subject: Reply with quote
Not sure how you loaded iGO up to an SD Card, unless you copied it, as iGO software is locked to the SD Card it comes on and only works on one device at a time. Where did you get the software from?
chelseafan
PostPosted: Wed Apr 23, 2008 2:01 pm    Post subject: SD Card Reply with quote
Thanks for response
Pulled the software from UNEXT. Copied it onto the SD card, everything Ok.
as per suggested directory structure.
no auto-load when SD card entered into PDA ?
DVD to SD card am I missing a step ?
PostPosted: Wed Apr 23, 2008 2:10 pm    Post subject: Reply with quote
pirate copy perchance? if so, end of discussion.
as stated above, igo is locked to the sd card it is purchased on and therefore cannot be copied to a different card.
