Pocket GPS World :: View topic - TT910 developed fault. Battery died?
nimh999
PostPosted: Fri Apr 18, 2008 9:11 pm    Post subject: TT910 developed fault. Battery died? Reply with quote
My TT910 has developed a fault. I have had it 13 months and the warranty has just expired. Just my luck.
When it's connected to an In Car Charger it will turn on, find it's GPS position and then turn itself off again. It might do this once, it might do this half a dozen times. It won't stay on for longer than 30-40 seconds.
It won't turn on at all if it's not connected to a charger.
I have tried rebooting, but have had no success.
Does anyone have any ideas?
Is it possible that the battery needs to be replaced?
If yes, can I replace it?
nimh999
PostPosted: Fri Apr 18, 2008 9:21 pm    Post subject: Reply with quote
mikealder wrote:
One other thought though, the 910 cannot be more than 2 years old as yet, even if it was purchased when the device first came out, so it should still be under waranty, a call to 0845 161 0009 might save you the hastle - Mike
Does the TT910 have a 2 year warranty?
PostPosted: Fri Apr 18, 2008 9:23 pm    Post subject: Reply with quote
You sure? Most TT's have a two year warranty.
It will tell you in the EULA in the "licences" folder on the TT itself. Make sure you read the right one.
tonys66
PostPosted: Fri Apr 18, 2008 9:31 pm    Post subject: Reply with quote
If it is defentley out of warranty then mike done some pics on this page on how to change it
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=66237
If you are not happy in doing it yourself then theres a link to a place that will do it for you
http://www.satnav-shop.com/index.php?ln=en&pg=2
That place is run by a guy from these fourms
nimh999
PostPosted: Fri Apr 18, 2008 9:43 pm    Post subject: Reply with quote
If I could turn it on.
nimh999 wrote:
mikealder wrote:
One other thought though, the 910 cannot be more than 2 years old as yet, even if it was purchased when the device first came out, so it should still be under warranty, a call to 0845 161 0009 might save you the hassle - Mike
Assuming you have made a backup have a look in the "Licences" folder and open the file;
lw-english-no_us can.txt
using WordPad (Note Pad will open it but it makes a mess of the end of line terminations)
lw-english-no_us can,txt wrote:
WHAT THIS WARRANTY COVERS
1) TomTom International B.V. (“TomTom”) warrants to you that the Hardware will be free from defects in workmanship and materials under normal use (“Defects”) for a period of two (2) years from the date that the Hardware was first purchased by you (“Warranty Period”). During the Warranty Period the Hardware will be repaired or replaced at TomTom’s choice (“Limited Warranty”) without charge to you for either parts or labour. This Limited Warranty covers the replacement of the Hardware only. If the Hardware is repaired after the Warranty Period has expired, the Warranty Period for the repair will expire six (6) months after the date of repair.
The exclusions clause does not mention battery so you should be OK, the post you took my quote from was a site member who had purchased a re-furbished device which does come with a different warranty to an outright new purchase.
Have you tried a different charger though? - what about when it is connected to the home dock and the supplied mains charger, does it behave the same way or not, either way you have it under warranty when you read the extract above (or look at the files on the unit) changing a battery in one of these devices is not the easiest of jobs unless you are used to handling electronics - Mike
