Pocket GPS World :: View topic - help please Guys
help please Guys
steve67474
PostPosted: Sun May 09, 2004 8:26 pm    Post subject: help please Guys Reply with quote
Hi ppl. I have a compaq 3570 and am running Destinator software on it no problems. I have loaded Tom Tom as well and after a while of messing around got it to see the sats. I set destinator GPS and serial COM1. I get 7 or 8 sats.My problem is that it cannot locate my position Question I have tried the "Correct GPS Position to no avail it says "position too large". The annoying thing is that I had this working with the destinator hardware last year I am running Tomm Tom 2and have uninstalled and re installed the software.
It just seems that it cannot pinpoint my location even with 7 or 8 sats. When driving it shows a blank map area with the arrow. Anybody out there have any ideas???
Thanks Guys
alix776
PostPosted: Sun May 09, 2004 8:48 pm    Post subject: Reply with quote
this may be a silly question but have you installed the maps and if so where have you insalled them 2 if your useing a bt gps use bt on com8
or bt gps after highlighting your receiver or try formatting the sd/mmc card
the maps install separatly fouther along the set up proceedure
device Lumia 950 xl
steve67474
PostPosted: Sun May 09, 2004 11:26 pm    Post subject: Reply with quote
thanx for the reply alex776. Yes I have installed the maps they r on a storage card and I can use navagate to go to a place and it will come back and saysomething like "when GPS has verified position will calculate route" I am using Destinator GPS Mouse and have tried all the NMEA settings. It only sees sats using Destinator GPS setting. This is the strange thing it can pick up sats and when I am driving the arrow rotates as I turn there is just no map reference?
Regards
DavidW
PostPosted: Mon May 10, 2004 10:05 am    Post subject: Reply with quote
Unless I'm misremembering, older versions of Destinator in particular run a SiRF based GPS in SiRF mode.
What happens if you try SiRF 38400? (I think they use 38400bps)
Exactly what do you see on the TomTom GPS screen (first tab - not the second tab where you configure your GPS)? The first thing you should see is scrolling dots, then a time and date (which will correct itself if it's wrong initially) and a number that will turn red even if they start out grey. Once you have three red bars at the bottom you have a fix. You should then have a speed, a longitude and latitude, and a direction.
Does all this data look plausible? Do the co-ordinates seem right for the country you're in? Do you have a map installed and selected that covers your location? What happens when you enter the co-ordinates on the TomTom GPS screen into the Tools -> Go to co-ordinates... menu options?
steve67474
PostPosted: Wed May 12, 2004 12:08 am    Post subject: Reply with quote
Thanx guys for replies . yes I have sats and the bars are red up to 7 of em I have maps loaded and can enter a destination. but it says destination will be calculated when gps position is available. I have a ? against my location. So all seems fine but it seems it cannot locate my position. I have tried all of the config options and the only one that gives me sats is the Destinator GPS all others show no sats at all. Have initialised the CF and reloaded tand updated to 1.53. I am getting a copy of 3 in afew days so that may fix the problem but this used to work
Totally confused as when I am driving it shows my speed and compass direction and all this changes as I turn and alter my speed so it has a fix on me but just a blank screen .
