Pocket GPS World :: View topic - Renault Scenic Windscreen
tyndareusone
PostPosted: Sun Mar 30, 2008 1:20 pm    Post subject: Renault Scenic Windscreen Reply with quote
Can anyone tell me if the Renault Scenic Windscreen blocks GPS signals to the Garmin Nuvi 350. Help would be much appreciated as I need the information by Monday before going to Spain where I will be driving a Scenic.
BeatO
PostPosted: Sun Mar 30, 2008 3:50 pm    Post subject: Reply with quote
Hi M8
I've a Renault Scenic and mine has a metallic windscreen coating to keep some of the heat out. To my knowledge, this is standard if it has an air conditioner installed. And then I know you won't be lucky with reception.
If you can, I'd advice on getting one of the small magnetic active antennas anyway, the reception is simply better. I use one any time I rent a car, even if not absolutely required.
In your case, as I assume that you have a rental car, hope for a "cheap" one, which does not have this feature. But if it has, note that around the rear view mirror in top center of the windscreen, you'll have an area with a black pattern around the mount of the mirror. That area is not coated.
But be warned, it's not easy to fit a built-in GPS antenna to get the signal through that tiny piece of "open sky".
BeatO
tyndareusone
PostPosted: Sun Mar 30, 2008 4:00 pm    Post subject: Renault Scenic Windscreen Reply with quote
Hi BeatO
Many thanks for your information and advice. I suspected as much as I had no joy in a Renault Espace. The Scenic belongs to my daughter and it has AC. Looks like an external antenna will be essential.
Tyndareusone
Johnny_boy
PostPosted: Sun Mar 30, 2008 10:42 pm    Post subject: Reply with quote
I have a 2007 Grand Scenic (imported from Malta) and it has Climate Control AC and I have no problems whatsoever with getting reception on a Nuvi 660. I normaly get all the bars on the strength meter. I also get the Traffic Signal reasonably well now that I've repositioned the wire horizontally.
regards
philai3
PostPosted: Mon Mar 31, 2008 12:54 am    Post subject: Reply with quote
I have an I3, and have had 4 scenics so far, last two have had automatic A/C.
2004 Scenic - needed external antenna
2007 Scenic - works fine on any part of windscreen. Salesman gave me some BS before I bought it saying that Renault had altered the windscreen coating - turned out he was right!
Garmin I3 October 2006
Garmin 1310 December 2009
(Firmware 3.2-2.7-3.4-2.7)
Renault Scenic with inbuilt Carminat Tom-Tom April 2013
Renault Clio
Mazda MX5 2010
cardiff_gareth
PostPosted: Tue Apr 01, 2008 7:49 am    Post subject: Reply with quote
I have a Renault Laguna II and my wife drives a Renault Scenic, both with A/C and UV screens. The Nuvi 250 works in both 100% with no need for an external ariel Wink
tyndareusone
PostPosted: Tue Apr 01, 2008 2:05 pm    Post subject: Renault Scenic Windscreen Reply with quote
My thanks to all who responded to my query. Did a belt and braces job and bought an external antenna to be on the safe side. I may have to drive my daughter to hospital at short notice for the birth of a granddaughter. Better safe than sorry. No doubt Murphy's Law will prevail now and I will find out that there was never a problem in the first place. Such is Life.
Tyndareus0ne
BeatO
PostPosted: Tue Apr 01, 2008 6:39 pm    Post subject: Reply with quote
Let us know how it turns out.
It looks like my Scenic II, delivered in late September 2003, which is from an early series of the new Scenic II model, has different coating used on the windscreen. Anyway, I don't mind the small antenna on my roof, it often helped me with reception while driving through town with lots of high buildings.
BeatO
tyndareusone
PostPosted: Tue Apr 01, 2008 6:59 pm    Post subject: Renault Scenic Windscreen Reply with quote
BeatO
I will be pleased to let you know how everything turns out. My next post may well originate in Spain where I am told daily temperatures are 20 - 22. Hope you don't think I'm rubbing it in but I probably am!!!
Tyndareusone
tyndareusone
PostPosted: Tue Apr 22, 2008 11:11 am    Post subject: Renault Scenic Windscreen Reply with quote
To allwho were kind enough to respond to my query.
As I suspected Murphy´s Law prevailed in a big way. There was no problem with the Scenic windscreen and I did not need to do an emergency run to the Hospital. My granddaughter was born on 20 April - both mother and child are well. By the time I get home I will have been in Spain for a month enjoying a mixed bag of weather and getting used to driving on the right!
Tyndareusone
bumpkin
PostPosted: Tue Apr 22, 2008 1:55 pm    Post subject: Reply with quote
Congratulations on the birth of your grand-daughter!
Did you get any grief from the Spanish traffic police, I understand that there's a rumour that GPS is now illegal in Spain as it's considered as a distraction! Going to Gerona in a few weeks.
Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10
tyndareusone
PostPosted: Tue Apr 22, 2008 2:57 pm    Post subject: Renault Scenic Windscreen Reply with quote
No grief from the Spanish Traffic Police at all but mu Nuvi was not really visible as it was propped in front of the rev. counter and I was listening and not looking very much.
I hope this is helpful. As far as the Spanish Traffic Police are concerned it may be a case of "If you have it DON´T flaunt it" After all, what the eye doesn´t see the Traffic Police may well ignore.
Tyndareusone
Lester_Burnham
PostPosted: Tue Apr 22, 2008 4:24 pm    Post subject: Reply with quote
re: the thing with sat navs and Spanish police...
If it's true, I wonder what the policy is with cars that have sat nav built in?
Surely an aftermarket sat nav should be no more of a distraction?
22.055 (29 May 24)
