Pocket GPS World :: View topic - Bluetooth problem with iPAQ 214
cartman
PostPosted: Thu Mar 20, 2008 2:47 pm    Post subject: Bluetooth problem with iPAQ 214 Reply with quote
When I try & run TT6 , I get the message
"The Bluetooth Radio failed to turn on due to insufficient driver memory available. You must perform a normal reset before you can turn on the Bluetooth radio"
I've tried that but the message just comes back again. The Bluetooth works ok with my mobile phone so I guess there's a software glitch with TT. Any clues please ?
ETC
hdv
PostPosted: Thu Mar 20, 2008 11:52 pm    Post subject: mine works fine Reply with quote
I have been using my iPAQ 214 with TomTom v. 6.030 for a while and never found such problem. Which TT version are you using?
cartman
PostPosted: Fri Mar 21, 2008 12:14 am    Post subject: iPAQ 214 Reply with quote
@ hdv
I have v6.032 (8351)
The message comes up in a box headed BTTrayCE. I've tried uninstalling TTN & then the BT connects perfectly with my GPS receiver so I'm sure it's a TTN problem. I recall a while back it was necessary to modify the registry to stop TTN opening the BT browser but if your system works without that, I can't see why mine shouldn't too !!
ETC
alan_sh
PostPosted: Sat Mar 22, 2008 12:16 pm    Post subject: Reply with quote
TomTom installs 2 DLL's which are older than the original ones for the 214. You just need to rename them, do a soft reset and then delete the renamed ones - the originals will then do the right job.
Now, you are going to ask which 2 DLL's they are - and I can't remember....
So, 1/2 an answer. If I find the names, I'll update this entry. If someone else has the answer, please add to it.
Alan
cartman
PostPosted: Sat Mar 22, 2008 10:40 pm    Post subject: 214 BT problem Reply with quote
Thanks to you both for taking the trouble to reply.
I'll have a play with the BT files in the meantime & see what I can find , in the hope that someone will come up with the right files to edit anyway !
ETC
wiz
PostPosted: Sat Mar 22, 2008 10:59 pm    Post subject: Re: iPAQ 214 Reply with quote
ETC
I have version 6.030 (8320) updated from Tom Tom site due to a problem with the display but don't have a problem with BT.
where did you get .032 from?
not had 214 for long, apart from the low sound levels its a gr8 piece of kit
what happens if the BT is already paired and running before you start TT?
hope you sort the problem soon.
Wiz
Alan --- aka Wiz.
Iphone 4S 16gb, ios 5 windows 7, CamerAlert, CoPilot & TomTom
cartman
PostPosted: Sun Mar 23, 2008 8:44 pm    Post subject: 214 BT problem Reply with quote
OK problem solved !
It occurred to me that the problem started after I'd been playing about with the pairing between my PDA & my phone. I did a hard reset, reinstalled TT & now it works , so I'm assume the BT stack was messed up or a file was corrupted.
Thanks again folks
ETC
22.062 (12 Jun 24)
