Pocket GPS World :: View topic - TV transmitter stations
marshall
PostPosted: Wed Mar 19, 2008 4:23 pm    Post subject: TV transmitter stations Reply with quote
Hi all
I am trying to find a poi's file for tv transmitter stations in GB to put on my go 520
Its just so I can line up my aerial while away in the caravan.
thanks
marshall Laughing
marshall TomTom Go 520 , Western Europe v805.1801 map. app 8.2204- v7KATE 4gb sd card + other cards
PostPosted: Wed Mar 19, 2008 7:16 pm    Post subject: Reply with quote
As far as I know there isn't one. However you could create one with the information from Here.
You can get the lat/long from the Grid Ref, inputting it into the Street Map Grid converter Here, using the Landranger entry option. The accuracy is in the order of 100 yards.
Just choose those that will be within range of your travels. Wink
aj2052
PostPosted: Thu Mar 20, 2008 2:11 am    Post subject: Reply with quote
Im not sure its worthwhile, I tried it once without a lot of success, It was hard getting a reading of the compass on the natsav without moving plus difficulty on getting a straight line from the transmitter, the best i could do was to try and line up for direction with a adjacent road and you need to ensure your map is pointing north, There is a website that gives you the nearest transmitter(s) and direction in degrees which i cannot remember at the moment but of course you would need access to web. I finished up rotating the aerial with the wife watching the screen for best picture.
PostPosted: Thu Mar 20, 2008 10:00 am    Post subject: Reply with quote
aj2052: satnav in 'north up' mode along with an actual real magnetic compass should suffice, surely?
philpugh
You could use the info on this site to create what you want. Location is 6digit OSGB. Lots of other useful info also.
Phil
aj2052
PostPosted: Thu Mar 20, 2008 4:22 pm    Post subject: Reply with quote
Yes MaFt , i think the only answer is to use a magnetic compass, and the website I used if i remember you only had to input your post code and it gave you the nearest transmitters and the bearing in degrees, a far simpler way than than trying to use GPS i would have thought, I will have to do a search. i also tried it using autoroute by drawing a straight line from transmitter to get a bearing but of course you need to know your actual orientation
marshall
PostPosted: Thu Mar 20, 2008 8:14 pm    Post subject: Reply with quote
hi all
many thanks for all your replies. it seems quite complicated
I think that using the name of the town where the transmitter is I should be able to work out the angle from my location. the gridlines on the map show me north so i use my trusty compass to show me the bearing of the transmitter town.
I hope it works and I will give it a try when i am next out
many thanks to all
marshall Wink
aj2052
PostPosted: Fri Mar 21, 2008 2:01 am    Post subject: Reply with quote
In view of the rolling changeover wouldnt it be easier to change over to freesat and use a satelite finder. i have seen these recently complete kit for around £70
theripper
PostPosted: Thu Mar 27, 2008 3:10 pm    Post subject: Reply with quote
For anybody that is interested I have just created an ov2 file of all Freeview transmitters in UK & NI and will send it in for inclusion on the download page, but if you can't wait you can download it from here
http://www.megaupload.com/?d=RRKW8W67
theripper
aj2052
PostPosted: Fri Mar 28, 2008 6:01 pm    Post subject: Reply with quote
For further information, this is the site, by inserting either your grid reference or postcode it will give you a bearing for both local and distant Analogue transmitters, also a page for Digital transmiiters.
http://www.wolfbane.com/cgi-bin/tva.exe?DX=L&HT=10&OS=le67+4bt
aj2052
For further information, this is the site, by inserting either your grid reference or postcode it will give you a bearing for both local and distant Analogue transmitters, also a page for Digital transmitters.
theripper
PostPosted: Mon Mar 31, 2008 3:18 pm    Post subject: Reply with quote
marshall
you have a pm
theripper
PostPosted: Tue Apr 01, 2008 2:09 pm    Post subject: Reply with quote
Below is a link to a POI file for the Analogue TV transmitters
http://www.megaupload.com/?d=U0PL0NW3
I will be uploading to PGPSW as well.
I am now working on all the relay stations but there are quite a few of them and it might take a couple of weeks.
theripper
theripper
PostPosted: Tue Apr 15, 2008 11:16 am    Post subject: Reply with quote
*****UPDATE*****
I have now finished all the analogue relay stations and the new file is now available for download here:-
http://www.megaupload.com/?d=4AT3C4J6
It contains 1084 main and relay transmitters for the UK including NI and I have included some icons that you can use if you want.
It will also be uploaded to PGPSW as well.
I am now starting a POI file for the Republic of Ireland transmitters.
theripper
Oldie
PostPosted: Thu Apr 24, 2008 7:12 pm    Post subject: Reply with quote
Look in the "Special Interest" category in the POI downloads Smile
Various TomToms, Garmin eTrex Legend, GPSMAP 60CSx, Oregon 550t, Forerunner 405
