dany_boy Occasional Visitor
Posted: Mon Mar 17, 2008 10:56 pm Post subject: help please making a diversity aerial |
hello all,
i hope this is in the correct section.
i have bought a diversity tuner for my car - it cam with a little magnetic base aerial which works ok - as its a diversity tuner it has connections for 3 other aerials.
i am going to make the other 3 as the one that came with it is just a length of wire, what i would like to know is do i connect both ends of the coax to it or just the centre core?
thanks in advance ,
Dan. |
simontdc Regular Visitor
Joined: 11/03/2003 08:29:43 Posts: 64 Location: United Kingdom
Posted: Tue Mar 18, 2008 8:24 am Post subject: |
You don't say what it's for - FM, TV or what? - I assume it's not GPS as it won't work without a special GPS receiver. As GPS makes range measurements from the satellites, having antennas in different places would confuse the receiver, stopping it using the satellites altogether. _________________ G1NTX AFRIN LRPS |
philpugh Lifetime Member
Posted: Tue Mar 18, 2008 2:28 pm Post subject: Re: help please making a diversity aerial |
dany_boy wrote: |
You should connect the central conductor and the outer sheath at both ends in order to reduce interference. _________________ Phil |
Posted: Wed Mar 19, 2008 2:49 am Post subject: |
sorry i forgot to mention its a 'universal diversity tv tuner', i thought diversity tuners were only for tv
thanks philpugh, i'm off to make a couple of antennas!
cheers.
Dan. |
Posted: Wed Mar 19, 2008 10:07 am Post subject: |
You can get diversity units for other frequencies/applications - usually used in cars - to help get the best signal strength. Look at any fully equipped police car - all the similar looking aerials will be connected to a diversity unit - usually. _________________ Phil |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Wed Mar 19, 2008 7:29 pm Post subject: |
And in 802.11 WiFi - that's why you see these wireless access points with two aerials...... _________________ Gone fishing! |
