Pocket GPS World :: View topic - BT308's auto charger and PDAs
RadioDog
PostPosted: Thu May 06, 2004 7:41 am    Post subject: BT308's auto charger and PDAs Reply with quote
Hello all,
Well, after all the initial problems, my BT308 is working beautifully with my e740.
But in the kit was a dual PDA/BT308 auto charger. I'm just wondering if I could use this to power my e740 and BT308 simultaneously or will it fry the insides of my li'l PDA. It seems that both devices draw 5V DC but have slightly different ampages.
Anyone try this with their e740?
Robbo
DavidW
PostPosted: Thu May 06, 2004 9:53 am    Post subject: Reply with quote
Different current draw isn't a problem if both devices need the same voltage. However, if the voltage drops with the combined current draw (that is, the power supply can't cope with powering both devices at once), or one device puts out excessive interference on the power supply, you may hit problems.
Unless a charger is clearly designated as being able to power both devices, I'd rather try to stick multiple hardwired cigarette lighter sockets behind my dashboard, and put a dedicated charger in each. However, I realise that may not necessarily be possible or easy to achieve.
Stevie
PostPosted: Thu May 06, 2004 12:25 pm    Post subject: Reply with quote
I have used the adapter to power both my Ipaq 3970 and the BT308 many times. On longer trips especially as the PDA is set to keep the display lit longer than when running on battery.
I only used the mains charger once when it was delivered, since then it's been stored away in the box.
RadioDog
PostPosted: Fri May 07, 2004 12:53 am    Post subject: Reply with quote
Thanks guys,
I might try the dual charger on my next road trip. Hope it doesn't doesn't frazzle my poor PDA Smile
Robbo
PostPosted: Fri May 07, 2004 9:22 am    Post subject: Reply with quote
Check out PC-Mobile they do a Y converter cable to split the power supply into 2 iPaq style plugs.
RadioDog
PostPosted: Fri May 14, 2004 2:13 am    Post subject: Reply with quote
...which leads me to ask, will my e740 take the iPaq style plug, current and voltage?
Rob
22.062 (12 Jun 24)
