Pocket GPS World :: View topic - Can't connect to bluetooth GPS
Jackoe
PostPosted: Sat Mar 15, 2008 10:50 am    Post subject: Can't connect to bluetooth GPS Reply with quote
Hi all - can I pick your collective brains? I am borrowing my wife's IPAQ Hx 4700 with globalsat bluetooth GPS receiver since my 4700 finally gave up the ghost a few weeks ago (waiting for a TyTN ii when my phone contract expires). I run TTN5 and have never had any problems connecting but suddenly tomtom has stopped switching my bluetooth on when I start up. Even if i switch on bluetooth and connect to the GPS before starting up tomtom I still cant get connected. I have been into tomtom and selected "other bluetooth gps receiver" in the gps options and set it to connect via com port 8. The GPS receiver is fully paired with the IPAQ. I have also successfully connected to the gps receiver using my "GPS PAD" software which shows the GPS is working fine and GPS signal is received fine by the IPAQ so I can only assume it's a tomtom problem but don't know where to go from here. Any suggestions appreciated
PostPosted: Sat Mar 15, 2008 11:19 am    Post subject: Reply with quote
Have you fully shut down the other GPS application before trying to run up TomTom, if GPS Pad still has a connection to the GPS the TomTom will not be able to see it - Mike
Jackoe
PostPosted: Sat Mar 15, 2008 7:06 pm    Post subject: Reply with quote
Yes- in fact I only loaded GPS pad to verify that the GPS was working and the problem was there before I loaded it. Thanks for the suggestion though-Alastair
wiz
PostPosted: Sun Mar 16, 2008 3:26 pm    Post subject: Reply with quote
used to have a similar problem from time to time with my old hx 2110.
this worked for me delete the pairing and soft reset then pair again, select your device in tom tom this used to sort it for months then it would happen again never did get to the bottom of it.
Wiz Very Happy
Alan --- aka Wiz.
Iphone 4S 16gb, ios 5 windows 7, CamerAlert, CoPilot & TomTom
Jackoe
PostPosted: Sun Mar 16, 2008 8:30 pm    Post subject: Reply with quote
Wiz Very Happy
Thanks- tried it but doesn't seem to have worked
wiz
PostPosted: Sun Mar 16, 2008 9:05 pm    Post subject: Reply with quote
[quote="Jackoe"]
Sorry it didn't work. Just a thought, you may of already done this....
when you paired the device did you select serial port and enable services ??
Alan --- aka Wiz.
