theberties Occasional Visitor
Posted: Thu Mar 13, 2008 2:58 pm Post subject: tomtom go720 |
for some reason when travelling from A46 Coventry area going towards M5 directions send me down M40 south to the next junction, round the roundabout and then back onto M40 instead of going onto M40 north, is it likely to be a mapping error or is there something in the settings i should change
bertie |
Andy_P Pocket GPS Moderator
Posted: Thu Mar 13, 2008 3:06 pm Post subject: |
For any question like this, the first thing you really need to tell us is the MAP version and the SOFTWARE version you're using. Then we can say whether it is a software glitch or a mapping error and whether it has been corrected in later versions already (or only appeared in later versions!!)
It's probably an error in the speed assigned to a single section of road.
You can check that by using the MapShare reporting facility if you have it. Unfortunately, there's nothing you can do (yet) to correct it yourself.
Navcore 8 will have the facility to change speed limits for road segments, but I'm not sure if that will also change the speed it uses for calculating times. |
CrispyUK Occasional Visitor
Joined: May 02, 2007 Posts: 24 Location: Hinckley, Leics
Sounds like someone has blocked the 'logical' sliproad route using MapShare? |
Johnny_D Regular Visitor
Joined: Mar 04, 2006 Posts: 119 Location: West Suffolk
Posted: Thu Mar 13, 2008 3:10 pm Post subject: |
CrispyUK wrote: | Sounds like someone has blocked the 'logical' sliproad route using MapShare? |
My thoughts exactly.
Has the opening poster downloaded the mapshare updates? If so what level of 'security' did you do?
JD _________________ TTG 300 Died the death of a cracked screen
Navman F20 USB Fell off
TTG 520 Third time lucky?
Bloody Superb PGPSW Camera Database.
Not much else! |
Oldboy Pocket GPS Moderator
Posted: Thu Mar 13, 2008 3:16 pm Post subject: |
I think it's the same problem that was discussed from This Post. _________________ Richard
Posted: Thu Mar 13, 2008 3:24 pm Post subject: |
For info, if you mean the area around N 52.25802 W 1.60037, it's still doing it on my Go720 with v7.221 software and v715 maps (on "fastest" route)
AND it doesn't matter if I'm using MapShare corrections or not... so it's not that.
Edit: well remembered Richard... |
Posted: Thu Mar 13, 2008 3:29 pm Post subject: |
Andy_P2002 wrote: | For info, if you mean the area around N 52.25802 W 1.60037, it's still doing it on my Go720 with v7.221 software and v715 maps (on "fastest" route)
That's a .
Must be a mapping error.
Not much else! |
Posted: Thu Mar 13, 2008 3:49 pm Post subject: |
In which case, maybe you CAN correct it with mapshare yourself (if it is a blocked section of roundabout, rather than an incorrect speed.
Go read that other post carefully, (as I'm about to do!) |
uffe73 Frequent Visitor
Posted: Thu Mar 13, 2008 5:47 pm Post subject: |
Andy_P2002 wrote: | In which case, maybe you CAN correct it with mapshare yourself (if it is a blocked section of roundabout, rather than an incorrect speed.
Ah the old classic Longbridge Roundabout is back in the forum. Try select the shortest route and you will be directed the correct way. The problem comes from incorrect map data for the roundabout which was discussed in the previous thread. |
Posted: Thu Mar 13, 2008 6:09 pm Post subject: |
thanks for replys. i have downloaded map share but hasn't made any difference. not a problem to me as i knew where i was going but i wondered why daughter in law got lost.
bertie |
