Pocket GPS World :: View topic - Blue circle round current location?
inspiredron
PostPosted: Wed Mar 05, 2008 9:49 pm    Post subject: Blue circle round current location? Reply with quote
I have just noticed a new feature on my 660. If I try to drag the map the current location acquires a blue circle round it. Has anyone else noticed this? I think that it is new since the update to unit software 4.20 and GPS 3.00.
missing_user
PostPosted: Wed Mar 05, 2008 10:42 pm    Post subject: Reply with quote
I do not have your unit but on both mine the blue circle is the 'Accuracy Circle'.
The smaller it gets, indicates the accuracy of the 'fix'!
PaulB2005
PostPosted: Wed Mar 05, 2008 10:49 pm    Post subject: Reply with quote
Doesn't do it here.... You are just doing this in View Map? With GPS On? Can you do a Screengrab?
inspiredron
PostPosted: Fri Mar 07, 2008 12:55 am    Post subject: Reply with quote
I'd bet it does! I tried again this evening and couldn't find it until I had zoomed up to a very large scale. As Strumble says it seems to be the accuracy of the fix and if the scale is too small the circle will be obscured by the car.
Forgive me if I do not post a screenshot but it would publish my home location! I am happy to pm you but even that should not be necessary. View map, zoom in to max and tap the screen.
missing_user
PostPosted: Fri Mar 07, 2008 9:24 am    Post subject: Reply with quote
What is the chance that the accuracy circle may well surround two members posting in the same thread, on the same website, happening again?
In my area all I get are seagulls and sheep! Very Happy
PaulB2005
PostPosted: Fri Mar 07, 2008 9:32 am    Post subject: Reply with quote
Well i can't get it to work. I zoomed right in and i drag the map round and a round and no circle...... Even with 5 bars of signal....
missing_user
PostPosted: Fri Mar 07, 2008 9:41 am    Post subject: Reply with quote
Paul,
I will admit that I do not get it if I drag the map around, only when the unit is trying to locate you at the present map position[ie your home].
There is the option on the iQue to select the Accuracy Circle, but I cannot find it on the 60CSX at the moment, but the screenshot shows the 60CSX.
PhilHornby
PostPosted: Fri Mar 07, 2008 1:48 pm    Post subject: Reply with quote
It's present on the Nüvi 310 as well.
inspiredron
PostPosted: Sun Mar 09, 2008 12:47 am    Post subject: Reply with quote
With 5 bars of signal accuracy will be good and circle small and therefore less easy to spot. Try it in the middle of your house.
On my 660 it is very visible with 4 bars.
HOWEVER ----- I then closed down the GPS - the ring became smaller but stayed. Powered down, then on again with GPS closed. Max zoom and blue circle diameter is 1.5 times width of car symbol!
So maybe it is not GPS accuracy. Might it be like finding the cursor in Windows by using Ctrl-click?
Curious
PostPosted: Mon Mar 10, 2008 1:46 am    Post subject: Reply with quote
The Blue Circle is an Accuracy Indicator, and it will not show on the iQue or Nuvi range once a specific level of accuracy is reached or exceeded. I have very rarely witnessed it on my Nuvi, because the Sirf chip is so good at attaining GPS signal. In fact if my memory serves me right the only time I have seen it is when i am visiting Edinburgh City centre (with all the very narrow streets and very tall buildings) and the Nuvi has just been switched on after a nights rest (First fix)
Please don't take what I am saying as an insult, its not intended.
One more point I would mention, although you units are showing good Signal strengths, what is the accuracy level. If you go into the GPS signal strengh page on your units (i.e tap the signal bars, and this will open a new page) it should tell you your accuracy in feet or meters
PaulB2005
PostPosted: Mon Mar 10, 2008 7:25 am    Post subject: Reply with quote
Question
I'm not sure how anyone could take offence at what you said. Very informative.
bush12
PostPosted: Fri Jul 25, 2008 7:55 am    Post subject: Round circle around the location Reply with quote
It is a question mark in the location. I do not post a screen of but it would publish my home location! I am happy with this location.
_____________________
bush
http://www.widecircles.biz
22.055 (29 May 24)
