Andy_P Pocket GPS Moderator
Posted: Sun Mar 02, 2008 11:08 pm Post subject: |
KnightOwl wrote: |
XDA Orbit using Tomtom v6.030 with UK and Eur maps
48 don't work,
24 do work
Paul |
Are you SURE?
44x44 work fine on TT 6, so I would have thought 48x48 would too.
What are you expecting to see? Don't forget they are ONLY used to make the already large flashing icon in the top corner of the screen as you approach a camera look less "blocky". |
GerryC Pocket GPS Moderator
Posted: Mon Mar 03, 2008 5:43 pm Post subject: |
Just tried the 44 and 48 on v6.594 on the XL and neither show up on the alert. This would appear to agree with TomTom's note saying that the large icons started on v7.
Does it work on a certain minor version of v6 onwards or just on certain units running it (eg Navigator)? _________________ Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount |
Posted: Mon Mar 03, 2008 6:18 pm Post subject: |
When I said the 44x44 worked fine on v6, I was just going by the chart on the download page. I haven't looked back through all the posts to check who said it... |
alistairm1 Regular Visitor
Posted: Tue Mar 04, 2008 2:15 pm Post subject: |
Just tested the 22 x 22 set with Navigon5 and POIWarner V2, and all work correctly.
Alistair |
Darren Frequent Visitor
Posted: Tue Mar 04, 2008 2:40 pm Post subject: |
Andy_P2002 wrote: | When I said the 44x44 worked fine on v6, I was just going by the chart on the download page. I haven't looked back through all the posts to check who said it... |
I took it from this post:
TheBrit wrote: | Using 24/44 with TT6 on SPV M3100. Looks great.  |
I have now removed the 44 support part from the table. _________________ Darren Griffin |
Posted: Tue Mar 04, 2008 2:41 pm Post subject: |
alistairm1 wrote: | Just tested the 22 x 22 set with Navigon5 and POIWarner V2, and all work correctly. |
Thanks Alistair, I have added this to the support table. _________________ Darren Griffin |
Posted: Tue Mar 04, 2008 4:11 pm Post subject: |
Apols, consider it now mentioned  _________________ Darren Griffin |
si740 Occasional Visitor
Posted: Tue Mar 04, 2008 9:07 pm Post subject: |
icons will not work on navman f20 ah well worth a try  _________________ If money dosn`t grow on trees why have banks got so many branches ?? |
lowie Regular Visitor
Posted: Thu Mar 06, 2008 9:55 am Post subject: |
Hmmm Installed the consolidated 44x44 icons on my 920 but I just get a red square for all of them. Any ideas?
Thanks |
Posted: Thu Mar 06, 2008 9:59 am Post subject: |
Try again, do the downloaded icons appear if you view them on the PC? _________________ Darren Griffin |
Posted: Thu Mar 06, 2008 10:37 am Post subject: |
lowie wrote: | Hmmm Installed the consolidated 44x44 icons on my 920 but I just get a red square for all of them. Any ideas?
Thanks |
Is this on the map or the alert in the top-left corner. If it's the map, you will need to load the 24x24 icons as well. _________________ Gerry
TomTom730T
Posted: Thu Mar 06, 2008 10:48 am Post subject: |
Hi Darren/Gerry
I have downloaded again and the icons are fine when viewed in Windows. The icons are the same on both the map and the flash just solid red. |
Posted: Thu Mar 06, 2008 11:22 am Post subject: |
lowie wrote: | Hi Darren/Gerry
If I understand you correctly, both the map and the alert are showing red boxes instead of icons. Correct?
Where have you stored the icons on the 720? They should be in the map folder along with the ov2 files.
Was it working OK with the default icons? If so you should have overwritten them with the 24x24 icons (Windows asks if you want to overwrite). It may be best to get back to a known working system and start again. _________________ Gerry
TomTom730T
Posted: Thu Mar 06, 2008 11:33 am Post subject: |
GerryC wrote: | lowie wrote: | Hi Darren/Gerry
Was it working OK with the default icons? If so you should have overwritten them with the 24x24 icons (Windows asks if you want to overwrite). It may be best to get back to a known working system and start again. |
Hi Gerry. I have been using the default icons on this system and the previous 6 TT systems i've had. ( Apologies for the slight sarcasm there)
How can you have the 24x24 and the 44x44 working together as I always thought it was one bmp file for each type of camera.
Thanks Steve |
