mikewall Regular Visitor
![](modules/Forums/images/avatars/95009122548de492ff09dd.jpg)
Posted: Sat Mar 01, 2008 2:46 am Post subject: Any tips On Traffic Info? |
Can't seem to get a decent signal no matter where i place the antenna! I'm using a TomTom Go 520, with the Traffic Module, in my car a Vauxhall Astra, and my Truck a Scania! My old Navman N60i and T1 worked ok but the TomTom seems much worse! I can't use the GPRS as i'm on o2 prepay and that doesn't support mobileweb! Does anyone have any tips? Thanks in advance. |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Sat Mar 01, 2008 8:41 am Post subject: |
For a start look at the RDS-TMC device near the connector and locate the small white flag with a number printed on it, the last three digits should be 013 if not you do not have the latest receiver and need to contact TomTom on 0845 161 0009 or take it back to where you bought it from.
Assuming you have the latest receiver, make sure the aerial is at least 5CM from the edge of the windscreen, I tend to run my aerial cable from the top left of the screen to the bottom edge, then across the dash to the unit which is mounted centrally. Reception can still be an issue depending upon where you live?? - Mike |
Posted: Sat Mar 01, 2008 4:40 pm Post subject: |
Ta just checked and the label does have 013! i live in Banbury don't get signal till i reach cherwell services then it's fine till i touch the M25 then if i'm heading along the southern stretch from M40 to Gatwick i have no signal for that whole stretch (the bit you need it most for) My navman was the same so i guess its a network issue as opposed to the reciever! but i would of thought that area would be well covered! |
Posted: Sat Mar 01, 2008 4:50 pm Post subject: |
Mike, I can send you a POI file that contains the transmitter locations and associated frequencies/ power levels to put on the unit, you can use this to work out what the correct frequensy should be and then enter it using the manual tune option - if you want it that is?
I detailed how to use it in This post - Mike |
gardenshed Frequent Visitor
Posted: Sat Mar 01, 2008 5:40 pm Post subject: |
mike if that poi file is for the whole country i wouldn't mind a copy of it as well please do you just drop it in the map file? |
Posted: Sat Mar 01, 2008 5:56 pm Post subject: |
Sent - Mike |
Posted: Sat Mar 01, 2008 7:24 pm Post subject: |
and already installed thanks very much ![Me Me Me](modules/Forums/images/smiles/55.gif) |
cazmar Regular Visitor
![](modules/Forums/images/avatars/gallery/harrypotter7.jpg)
Posted: Sun Mar 02, 2008 10:54 am Post subject: poi file |
Mike please could you send me the file if possible.Thank-you.Mark. |
Posted: Sun Mar 02, 2008 7:30 pm Post subject: poi file |
Thank-you Mike.The file was gratefully received and installed. |
AngelGabriel Occasional Visitor
Posted: Sun Mar 02, 2008 11:44 pm Post subject: |
Mike
Any chance you can send me the file too please - I am having the exact same problem although the last three digits on mine are 000
Thanks!!! |
Andy_P Pocket GPS Moderator
Posted: Sun Mar 02, 2008 11:58 pm Post subject: |
AngelGabriel wrote: | although the last three digits on mine are 000
If that's the case I don't think it will EVER work satisfactorily.
You should contact TomTom for a replacement. |
Posted: Mon Mar 03, 2008 12:17 am Post subject: |
AngelGabriel wrote: | Any chance you can send me the file too please - I am having the exact same problem although the last three digits on mine are 000 | I have sent you the files but as Andy has said unless you have the unit with the 013 code you are going to have a strugle to say the very least. Give TT Support a ring in the morning and demand a replacement RDS device, as they have been handing them out as a free replacement for earlier units (that simply didn't work), if you need the phone number scroll up this page to my first post in the thread to find it - Mike |
Posted: Mon Mar 03, 2008 3:29 am Post subject: |
Yes please Mike that would be great thank you. thanks again. |
Posted: Mon Mar 03, 2008 6:19 am Post subject: |
Mike, it should be in your inbox by now as I sent it on Saturday around 17:00HR - I also removed your e-mail address from your last post as it attracts spam if you put it in public view that way - Mike |
agolder Occasional Visitor
Joined: Jan 08, 2008 Posts: 7 Location: West Yorkshire, UK
Posted: Mon Mar 03, 2008 8:55 pm Post subject: |
Mike, please could you send me the file too?
Many thanks. |
