sixarm Occasional Visitor
Posted: Fri Feb 01, 2008 10:56 am Post subject: Garmin Mobile XT - Speed Camera POI's |
Hi all,
I've recently installed Garmin Mobile XT v4.10.60 on my Nokia N95 and am really quite impressed. I got hold of a POI.GPL file, which apparently contained a Speed Camera database for the UK.
My problem is that when approaching speed camera's in a 30 mph zone it flashes up a warning on screen saying "19 mph". If I happen to drop below 19 mph, the warning will stop. Surely it should warn you if you are doing more than 30 mph? Is there any way to change this?
It does the same for 40 mph but flashes up 25 mph. Is this an issue with the POI's or the Software itself?
Also, are there any POI files within the Speed Camera database on this site that are compatible with this version of Mobile XT?
Many thanks. |
Posted: Fri Feb 01, 2008 11:12 am Post subject: |
Hi and welcome.
Can i ask where the POI.GPI file came from?
The problem you are experiencing is a common one. It is caused by someone loading the database with a KPH setting in POILoader instead of MPH. The only way to fix it is to reload the database and use the MPH setting. |
Posted: Fri Feb 01, 2008 11:36 am Post subject: |
That makes alot of sense, thanks!
This is where I got the file from:
Link removed by ADMIN
5th post down by BuMobiles.
So, I've got POI Loader installed, where can I get the original Database from?
Many thanks. |
Posted: Fri Feb 01, 2008 11:45 am Post subject: |
The download you got is almost certainly a pirate download.
You get legitimate copies by subscribing here. Click on the yellow camera logo at the top left or click here |
Darren Frequent Visitor
Posted: Fri Feb 01, 2008 11:54 am Post subject: |
sixarm That file and link is for pirate software. The file is only available to legitimate subscribers to Garmin's database. I have removed the link and notified Garmin of its existence.
Can I ask you please not to post it again. You may not have realised it was pirated but then again, anyone using that web-site can be in little doubt having read the discussion. _________________ Darren Griffin
Posted: Fri Feb 01, 2008 12:00 pm Post subject: |
Darren just beat me to the edit... |
Posted: Fri Feb 01, 2008 1:07 pm Post subject: |
I thought as much, and can only apologise.
So, where can I legitimately get hold of a Speed Camera database file to use with POI Loader? |
Posted: Fri Feb 01, 2008 1:10 pm Post subject: |
There are two sources, either subscribe to Garmin's database which isn't great to be honest as many Garmin owners will confirm or ours? _________________ Darren Griffin |
Posted: Fri Feb 01, 2008 1:18 pm Post subject: |
I'd certainly like to subscribe to yours. So there are files on your database that are definitely compatible with Mobile XT? |
Posted: Fri Feb 01, 2008 1:20 pm Post subject: |
If it uses POILoader then yes, we have a POILoader compatible set. _________________ Darren Griffin |
madmorphie Occasional Visitor
Posted: Fri Feb 15, 2008 9:53 pm Post subject: |
hi i have the same questions as above im allready a subscriber but im baffled as to which files to use from the list of garmin ones....any chance of a link to the correct set and a lil how to on how to upload them please....ive only done tomtom before and that was easy....cheers in advance....andy |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15148 Location: Bradford, West Yorkshire
Posted: Fri Feb 15, 2008 11:15 pm Post subject: |
if it can use POI Loader (garmin.com/poiloader) then use the 'Garmin POILoader' version.
if it comes with mapsource then you may be able to use the GPX files from 'Garmin Other' ?
what does the manual say?
MaFt |
Posted: Sun Feb 17, 2008 2:41 am Post subject: |
cracked it ....use the poi loader with the csv extension poi's and it works a treat.....greatstuff thx alot...... |
paul2468 Occasional Visitor
Posted: Sat Oct 08, 2011 8:47 pm Post subject: garmin mobile xt |
Could you tell me where on my micro sd card I load the speed camera database for the garmin xt software to be able to use it / see it. Sorry if this seems a bit of a stupid question. |
Posted: Sun Oct 09, 2011 10:08 pm Post subject: Re: garmin mobile xt |
paul2468 wrote: | Could you tell me where on my micro sd card I load the speed camera database for the garmin xt software to be able to use it / see it. Sorry if this seems a bit of a stupid question. |
As per the post prior to yours, you need to use Garmin's POILoader app, that will dictate where the files go. _________________ Darren Griffin |
