Pocket GPS World :: View topic - Tomtom MAP V7.15 problem
cyberbot
PostPosted: Wed Feb 13, 2008 9:40 pm    Post subject: Tomtom MAP V7.15 problem Reply with quote
Hey guys
Tomtom has release new map V7.15 and i am having abonement with them. the map is Western And central Euroup
i have downloaded the map wich is 1.89 GB
but my TOmtom 720 have only 2GB in Hardisk
my questions is Can i use External SD card like 4GB and install there the Map and Application
and Hardisk of my tomtom 720 leave it free for music or something like this ?
Any help pls ?
Tim Buxton
PostPosted: Wed Feb 13, 2008 9:51 pm    Post subject: Reply with quote
Yes. It doesn't matter where the application is stored, except that if you have applications on both internal and external memory devices, the external one will take precedence. Maps can also be installed on either medium and all maps will be available, provided they are properly activated, wherever they are stored.
Tim
cyberbot
PostPosted: Wed Feb 13, 2008 10:01 pm    Post subject: Reply with quote
Like if buy SD 4GB and i install there The Application the map
and my HD stay Empty
Like this way it gonna works ?
if the application and map Separated ( application in SD and map in HD )does it work so or not ?
exportman
PostPosted: Wed Feb 13, 2008 11:16 pm    Post subject: Reply with quote
I am not sure the tom tom will recognise a 4gb card tried one in both a rider 2 and 1 xl and it will not read it.
Hoppy
PostPosted: Wed Feb 13, 2008 11:57 pm    Post subject: Reply with quote
exportman wrote:
The TT x20's do support 4gb cards, they will even read 8gb cards as I am using one in my 520.
TomTom Go 950 Live.
App 9.054
Europe v8.50
NA 2GB v8.45
PostPosted: Thu Feb 14, 2008 12:56 am    Post subject: Reply with quote
Yes, it gonna.
It work.
cyberbot
PostPosted: Thu Feb 14, 2008 6:33 pm    Post subject: Reply with quote
I have heard From my brother he is using 8GB in his tomtom 720 in Sweden
i bought today one 8 but my Tomtom Doesnt know there is 8 GB but only 4GB
is there is any trick of fixing this ?
PostPosted: Thu Feb 14, 2008 7:55 pm    Post subject: Reply with quote
Format the 8GB card under Windows Explorer using an SDHC compatible reader connected to the PC, then use the full capacity as intended. You will have to load files (music, maps etc) via the card reader as the x20 cannot correctly use the SDHC card at this capacity when in PC connected mode, it is fine once you have the data on the card and working though - Mike
cyberbot
PostPosted: Thu Feb 14, 2008 9:58 pm    Post subject: Reply with quote
Can you tell how to Formate under windows Explorer?
PostPosted: Thu Feb 14, 2008 10:36 pm    Post subject: Reply with quote
Put the card in an SDHC compatible reader (not the TomTom unit as its not capable of doing this currently) and insert it to a USB slot on the PC, locate the card in Windows Explorer, right click it and select format from the list of options presented.
As a tip don't have the TomTom device connected when you do this, if you get the drive letter wrong you could wipe the internal Flash memory through a simple mistake - Mike
cyberbot
PostPosted: Fri Feb 15, 2008 6:19 pm    Post subject: Reply with quote
Done
i formate the Card with Fat32 but it still not Avaible in my tomtom
So my tomtom doesnt know there is SD who have 8GB
PostPosted: Fri Feb 15, 2008 6:54 pm    Post subject: Reply with quote
Put the card in the reader and copy the required files to the card using Windows Explorer, make sure you put the files into the correctly named folders.
Once the data is on the card insert it to the 720 and you will find it can read the data.
Music files go into a folder named "mp3" (without the "") the "mp3" folder should reside in the root of the memory card.
What are you trying to put on the 8GB card? - Mike
cyberbot
PostPosted: Sat Feb 16, 2008 10:37 am    Post subject: Reply with quote
Well what i am trying to put in the SD8GB is my New map what i'v Got from tomtom Western And Central Euroup V7.15 wich is 1.91GB
and my Tomtom HD is only 2GB
So i thought to get 8GB for the future if there is something new i wont be bothered.
about the SD Card, Maybe the Tomtom Doesnt know it because it another mark ( name ) or not ( KINGSTON)
22.055 (29 May 24)
