Darren831 Occasional Visitor
Posted: Sun Feb 10, 2008 2:41 am Post subject: Help...Multi Stop Route Optimising. |
Help.
I need to buy a Sat Nav for my car. I do 10 stops per day and when I leave I want to key in all 10 destinations then I want the sat nav to calculate the fastest route round them all starting form home and ending up back at home.
Is there such a device?
Thanks. |
alix776 Pocket GPS Moderator
Posted: Sun Feb 10, 2008 10:53 am Post subject: |
i would recomend either copilot 10 stops max or iGO as ive never yet hit the stop limit if memory derved correct then i think its about 99 stops both applications can optimize roue on the fly _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Sun Feb 10, 2008 1:28 pm Post subject: |
I'm with Alix776 when he says Quote: | too much stuff to list current fav software iGO
I changed from TT to iGO and find it does all I want and more. You can tap in your destinations (via's) by Address, Postcode, Co-ordinates or by a tap on the screen. You can insert a push pin which makes it dead easy to tap on one and add as a via. Optimisation is fast, as is routing. You get a choice of Car, Lorry, Bus, Emergency vehicle, cycle or walking and Fastest, Shortest or Economical.
The PGPSW Safety cams can be added easily and a bonus, over the TT, is you only get a warning of speed cameras if you are over the limit, and they are directional so no false alarms.
Well worth putting on your list for comparison with others. |
alan_sh Lifetime Member
Posted: Mon Feb 11, 2008 4:07 pm Post subject: |
Alternatively, Autoroute 2007 has an "optimise stops" so you can do all your planning on a PC. Then use some converter software (e.g. ITNConv) to change it to Garmin or TomTom etc and then just upload it to your device.
Alan |
Posted: Tue Feb 12, 2008 10:31 am Post subject: |
Lost_Property wrote: | I'm with Alix776 when he says Quote: | too much stuff to list current fav software iGO
due to iGO being linked to the sd card im mainly using cp7 now as i have everything on one device though iGO still does get used when i get to many drops to input into copilot _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
garcor Regular Visitor
Joined: Feb 10, 2008 Posts: 114 Location: Nova Scotia & Florida in Winter Go 920 App 8.351 Maps NA 850 & C/W EU 830
Posted: Wed Feb 27, 2008 11:30 pm Post subject: tt or garmin and maping |
I also think it is a personal preference as to TT or Garmin.
I just bought the TT Go 920 and I like many of the features on it over any other GPS out there at the moment.
(1) First of all it is loaded with 4GB of internal memory and will also handle a 4GB SD card giving you a total of *GB of memory.
(2) It comes with a remote so you don’t have to be reaching and touching the screen while driving especially good if you have in mounted on windshield and a deep dash.
(3) The best feature that I found with it is that you can plan say 1000 Mile trip on Google Maps and and using the Google Map interface drag the rout and make any changes that you would like and then save it as an itn file.
(this can be done by using this sitehttp://houghi.org/tomtom/index.php) on your TT or SD Card and when you are ready just upload it and you are all set to go. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15156 Location: Bradford, West Yorkshire
Posted: Thu Feb 28, 2008 2:55 am Post subject: |
as a PND rather than software, the garmin nuvi 7xx range has multiple waypoints / trips and works very well.
MaFt |
Posted: Thu Feb 28, 2008 8:04 am Post subject: |
yes MaFt that is true but if you get out of the van its something else to carry or hide aswell as a phone all this takes time so a pda or pdaphone with gps is the easier solution as there would be less to carry around _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Thu Feb 28, 2008 10:19 am Post subject: |
true, but i was just giving all the options he ight not have a pocket pc? |
Posted: Thu Feb 28, 2008 4:49 pm Post subject: |
Quote: | true, but i was just giving all the options he ight not have a pocket pc? | Maybe he should, he could then keep a list of all his 'customers' in Contacts and pluck them out as and when required. |
