Pocket GPS World :: View topic - Problem sending maps to Etrex Vista CX
TranceraUK
PostPosted: Thu Feb 07, 2008 5:26 pm    Post subject: Problem sending maps to Etrex Vista CX Reply with quote
Ive hit upon a lil problem sending maps from mapsource to my vista cx
Usually im sending about 100 maps of my area about 130mb without any probs. So i decided to expand my maps.
What happens is if im sending a map file over about 250mb after about 5 mins i get an error in mapsource saying that the device has been disconnected as if its timed out or something. So ive found out a way to send the maps directly to my hd then send them to the unit in mass storage mode. But after about 2 mins i get an IO error even though my Vista CX has 1gb of memory.
Any help would be appreciated guys.
PostPosted: Thu Feb 07, 2008 5:43 pm    Post subject: Reply with quote
Is there a limit to the size of single map 'cuts'?
burtonian
PostPosted: Fri Feb 08, 2008 1:39 pm    Post subject: Reply with quote
Have you tried sending the maps direct to the sd card using an sd card reader instead of it being in the unit?
TranceraUK
PostPosted: Fri Feb 08, 2008 5:26 pm    Post subject: maps Reply with quote
Hi burtonian,
I never thought of that so i just tried it and got the same problem.
so just for a test i sent a 500mb .avi file to the card and that worked ok.
is the garmin gmapsupp.img file compressed and mabe this is the problem and i need a 2gig card.
philpugh
PostPosted: Fri Feb 08, 2008 6:12 pm    Post subject: Reply with quote
Is there a limit to how much you can add into the base memory of the unit? I seem to recall that although my nuvi reports X Mbytes free I cannot add files to that size. If you can add a card into the unit then this may be something to try.
Phil
burtonian
PostPosted: Fri Feb 08, 2008 6:18 pm    Post subject: Reply with quote
I sent all GB Topo map tiles (about 1.6Gb) to a 2Gb sd card, no problems. That's a garmin map image created by Mapsource. Took only a few minutes using the sd card reader, took about 3 or 4 times longer using the mass storage option on my Legend HCX. Sounds as if you're trying to create too big an img for your card.
edit @ phil : if it's a cx then the internal memory can't be overwritten and I assume Trancer is already using the sd card slot.
philpugh
PostPosted: Fri Feb 08, 2008 6:26 pm    Post subject: Reply with quote
Ah Embarassed
I would go for the 'send direct to card' option then!
Phil
TranceraUK
PostPosted: Fri Feb 08, 2008 6:27 pm    Post subject: memory Reply with quote
Phil & burtonian
Thanks for the replies dudes after some experimentation its all pointing to the fact that ill have to put a 2gb card in the unit.
Niceone Lads
TranceraUK
PostPosted: Sat Feb 16, 2008 11:29 am    Post subject: Sussed Reply with quote
Ive just been out and bought a 2gb SD Card and was having the same problem. BUT ive sussed it out. The problem was I was using a 4 port USB hub so as a last resort I plugged the card directly into the computer and hey presto all working ok.
So i didnt really need the 2gb card after all but I suppose it will come in handy.
Carl
