Pocket GPS World :: View topic - 910 Charging Problems
harleybuell1
PostPosted: Sun Jan 27, 2008 9:30 am    Post subject: 910 Charging Problems Reply with quote
Hi, I have searched for this topic but can't find it so apologies if it is here somewhere and I have missed it. Anyway I have a really annoying problem with my 910 .........
The unit works and charges fine in its PC dock, however when I put it in the car dock the power eventually runs down (no power taken from car, only uses battery) until the battery flashes red and eventually switches off.
The yellow light on the 910 unit comes on
I have a standard and FM dock and it does it on both
When tilting the unit in the dock sometimes the battery warning light goes out
I have had a look at the power point on the unit (sprung loaded pin within small brass circle?) and it seems to be fine
The unit charges fine in the PC dock which has the same power link system
Has anyone had this problem or got any advice?
Many Thanks,
Garry
PostPosted: Sun Jan 27, 2008 9:42 am    Post subject: Reply with quote
Get it reported under warranty tel 0845 161 0009 it sounds like a connection problem although it could be the car charger adaptor that is causing this.
The sprung loaded ring with a center pin is in fact the contacts used for an external GPS feed aerial - Mike
harleybuell1
PostPosted: Sun Jan 27, 2008 10:04 am    Post subject: 910 Charging Problem Reply with quote
Thanks, I will give them a call on Monday, I'll also get another charging cable just incase that cures it.
Garry
PostPosted: Mon Jan 28, 2008 12:38 am    Post subject: Re: 910 Charging Problems Reply with quote
Don't mess with that....It's not the power connector but the external AERIAL socket.
The power goes through the long multiway connector.
harleybuell1
PostPosted: Thu Feb 07, 2008 9:55 pm    Post subject: Dump the Tom Tom Reply with quote
Laughing Thanks for your replies. I decided to bin the Tom Tom as this is the third time (others on PDA) that I have had problems with and I finf their back up really bad (Now on a Garmin NUVI ... so we'll see!)
Garry
stuart
PostPosted: Mon Feb 11, 2008 11:36 pm    Post subject: Charging problems Reply with quote
I have been having similar charging problems with my 520T. It charges up OK in the dock, but on the road, with the 12V charger plugged in, it crashes after 4 hours. Today I had to wedge the usb plug into the socket and all was fine. I have just contacted Dixons and asked for a replacement..Its only 5 weeks old.
PostPosted: Tue Feb 12, 2008 2:20 pm    Post subject: Reply with quote
I think this may become a "standard problem" in time,
Mini USB sockets were never really designed for the sort of use we put them to.
For a SatNav, you can expect to connect and disconnect several times a day
The Mini-USB specification seems to be only 1,500 mating cycles (or 5,000 for the “mini-B” connector). (see http://www.usb.org/developers/docs/ecn1.pdf)
So, if you ONLY use your SatNav to go to work and back, that's 2 cycles a day or an expected life of less than two years!
On top of that, the solder joints holding the socket to the motherboard are probably even less durable, and more likely to fail under slightly rough handling.
I notice the new "Micro-USB" connectors, developed for mobile phones will have a spec. of 10,000 mating cycles.
(http://www.usb.org/press/pressroom/2007_01_04_usbif.pdf)
