tubbs Occasional Visitor
Posted: Tue Feb 05, 2008 12:39 am Post subject: TT720, Have made it very sick......... |
Hi all,
I have updated my 720 and added some POI's. It does not seem to have appreciated this as it will not boot now. TThome comes upwith error message 'devicenavcoreversion missing'. First time I have messed with it and I have killed it!!!
Any help gratefully recieved as how to get it up and running again.
cheers Tubbs  |
dhn Frequent Visitor
Posted: Tue Feb 05, 2008 1:01 am Post subject: Re: TT720, Have made it very sick......... |
tubbs wrote: | Hi all,
cheers Tubbs  |
Restore from a backup? |
Posted: Tue Feb 05, 2008 9:59 am Post subject: Re: TT720, Have made it very sick......... |
dhn wrote: | tubbs wrote: | Hi all,
cheers Tubbs  |
Hi there, back again
have tried a restore, it went through the motions and the screen(TThome) said restore complete. i restarted my 720 and we still have the same problem. when it tries to boot,i get the tomtom startup picture then a picture of my tomtom with a green background.
It then comes upwith an SD icon,but this goes and an icon for a hard-drive appears along with a progress bar along the bottom of the screen and a big red cross that disappears when the progress bar has completed its trip across the screen.
hope this helps somebody realise how to fix this
thanks in anticipation
Tubbs |
Andy_P Pocket GPS Moderator
Posted: Tue Feb 05, 2008 11:24 am Post subject: |
First, make a proper backup:
1. Connect the TomTom to the PC
2. Close Home if it opens
3. Open Windows Explorer and navigate to the new Hard Drive that Windows will have called the TomTom's storage.
4. When you can see the contents of the TT's storage (a long list of files and folders) in the right hand side of the Explorer window, go to the Edit Menu and "Select all", then "copy"
5. Go back to your desktop and right click on an empty space.
6. Select "New Folder" and give the folder a name (Something like "TT backup_{and today's date}")
7. Right click on the new folder and select "paste"
You should now have completed a "Full Windows Explorer Backup". These are "better" than ones made by Home.
Now to DELETE the existing software
1. Browse back to the TomTom's storage in Windows Explorer
2. Find the files (probably at the bottom of the list) that are NOT in any folders. There will be about 30-40 with names like "data.chk" and "system" and "ttsystem".
3. Select ALL of those files that are NOT in yellow folders (click on the first in the list then SHIFT-click on the last one to highlight them all) IMPORTANT: The folders with their content must NOT be selected.
4. Now right click in that selected section and choose "delete"
You have now deleted the original system files from the TT.
Now to replace it
1. Run Home and wait for it to recognise the TT.
2. Go to "Update my Device"
3. Home will now do one of two things. If you have already updated the software on your device, Home will attempt to reinstall the latest version from where it is stored on your PC. If you haven't, it will attempt to download it and install it from the internet. |
Posted: Tue Feb 05, 2008 2:53 pm Post subject: |
me again,
Thanks for that Andy.
I have followed your instructions and when it came to update my device, it said it was up to date, but the I got
'required parameter navcoreversion missing' again.
somehow I have made it very ill...
Any more ideas gratefully accepted
Cheers Tubbs |
Posted: Tue Feb 05, 2008 3:00 pm Post subject: |
So you have DELETED all the loose files from the Go itself, and you are still getting that message?
Ahh, light maybe dawns... Have you got an SD card in the slot?
If so, remove it and do the whole delete/ reinstall again.
Next, are you using Home v2.2 and I presume you have been selecting "internal memory when Home starts up?
If not, you'll need to install Home v2.2 before you can do anything else. |
Posted: Tue Feb 05, 2008 4:18 pm Post subject: |
hi there,
still got nothing happening
i have a nice picture of the go onscreen
and home says a new application has been installed recently, disconnect the device and then switch it on and reconnect to computer.
have tried about 6 times, but it still comes back to the nice picture
arghhhhhhhhh
cheers
Tubbs |
Posted: Tue Feb 05, 2008 4:32 pm Post subject: |
OK my last shot...
Remove any SD card.
Go into TomTom Home and click on file / exit.
Now go into My Documents on your PC / TomTom / Home / Downloads / Program (or wherever you have Home set to store its downloads). Delete everything that is in this folder.
Connect the TT to the PC and delete all the loose files from the TT internal memory again (as you did above)
Now start TomTom Home again and click on update my GO. This will force Home to download a fresh copy of the software. |
Posted: Tue Feb 05, 2008 4:47 pm Post subject: |
ARGHHHHHHHHHH
Hi Andy,
sorry to inform you, but we are still in the same state.
home says the device is up to date
there are no loose files
have emptied the home/downloads/program folder and still it says the device is up to date, but am still looking at the pretty picture
cheers Tubbs  |
Posted: Tue Feb 05, 2008 4:50 pm Post subject: |
Just out of interest, what is the pretty picture?
As far as I know the normal startup picture is one of those "loose" files (splashw.bmp), so if you've deleted them all, you shouldn't get it. |
Posted: Tue Feb 05, 2008 5:00 pm Post subject: |
Hi again'
The picture is a photo of the go in its usb dock, on a green background with a white border with the words TomTom GO720
cheers Tubbs |
Posted: Tue Feb 05, 2008 5:07 pm Post subject: |
Ah.. OK. That's hard coded into the device. For a minute I thought you meant a real pretty picture like the road with the signpost and the clouds start-up pic.
I think I'm going to have to pass this to someone else for a while, see if they can crack what we're missing. |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Tue Feb 05, 2008 6:03 pm Post subject: |
Andy_P2002 wrote: | Connect the TT to the PC and delete all the loose files from the TT internal memory again (as you did above)
tubbs wrote: | home says the device is up to date | If you have deleted ALL the loose Files on the Device, HOME should not report that it is up-to-date, because there will be nothing there for it to read.
Have you removed the SD Card, if you have one? _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
Posted: Tue Feb 05, 2008 6:35 pm Post subject: |
Hi Richard,
have just checked again and all of the loose files are gone, only folders left.
Just tried again and again it said device up to date
still getting the message
[b][u]Unplug your tomtom device
A new application has been installed on your device recently. Please click 'Disconnect your device' in the device menu.
Unplug your tomtom device from your computer and switch it on.
Connect your tomtom device to your computer again.
Can I just go back to the original message i was getting-
'devicenavcoreversion missing' in tomtom home.
hope all this helps, btw, dont have SD card in and not had one in, if that makes a difference.
thanks for your time
Cheers Tubbs |
Posted: Tue Feb 05, 2008 6:41 pm Post subject: |
tubbs wrote: | Hi Richard,
Cheers Tubbs |
Sorry.....just a bit hard to follow what has and hasn't been tried. Have you tried a reset with a paperclip? |
