Pocket GPS World :: View topic - Favorites lost
Favorites lost
Jacklad
PostPosted: Sun Feb 03, 2008 4:47 pm    Post subject: Favorites lost Reply with quote
I run TT5 on an IPAQ HX2750 (windows mobile 2003)
Maps on an SD card.
Several times recently when I have started up TT it starts OK, but I have no favorites ? ... it is 'greyed' out on display.
Not even my home location.
I put them back in, and it may be OK for a couple of weeks .. but then ... it goes again.
Is this a known issue ? Is there a fix.
I don't think it's a memory card issue as maps are never affected.
Oldboy
PostPosted: Sun Feb 03, 2008 5:22 pm    Post subject: Reply with quote
This Thread will probably help you.
A quick Search for cfg losing in the Navigator Forum will return quite a few more. Wink
Jacklad
PostPosted: Mon Feb 04, 2008 3:48 pm    Post subject: Reply with quote
checked the SD card sw - OK
Checked Read only is not set of .cfg file
As this works 75% of the time, assume general setup must be OK ... it's just that a couple of times month .. it loses all config.
My HP does it's soft reset now and again on power up as the Fingerprint/encryption ( Credant Guardian ) fails on start up.
But this should not lose data on an SD card.
Anybody any other suggestions ?
PostPosted: Mon Feb 04, 2008 5:46 pm    Post subject: Reply with quote
Make sure you exit the TomTom application correctly BEFORE switching the PDA off, if the PDA is writing to the card or more specifically the .cfg file when you de-power the device there is a chance you will corrupt the file, the next time you start the navigator it will delete the corrupt file and start again creating a new one, net result is a loss of all settings.
Backup the .cfg file to another folder and next time it corrupts simply copy/paste the backup .cfg into the map folder and your settings will be back to normal - Mike
Jacklad
PostPosted: Mon Feb 04, 2008 6:02 pm    Post subject: Reply with quote
That might be it ...
Good tip on copying the file, once I rebuild the Favorites, I'll save a copy.
