Eugene7 Lifetime Member
Posted: Thu Jan 31, 2008 9:54 am Post subject: |
I have found that setting up an Itinery with local roads and lost of turns, and then running demo mode, shows the problem too, so it's easy to check if things are working.
You can run demo mode faster than real time, and the result is the same.
Would appreciate others trying this to see what they get - errors or no errors. |
stevengirdham Occasional Visitor
Posted: Thu Jan 31, 2008 7:59 pm Post subject: |
I just got a new sandick 8 gig micro card today coped all from other card . i have also been in contact with tomtom told to put voices into main memory like you did and did not work, then told by tomtom to also put voices in storage card as well just tyred a little route was OK. need to to do a longer journey at weekend let you know |
Posted: Fri Feb 01, 2008 12:48 am Post subject: |
just tyred what you said set up a Itinerary and yes it still cut of half way through a sentence |
Posted: Fri Feb 01, 2008 10:54 am Post subject: |
Ok, this is getting interesting.
I have now found that using a 'Y' adaptor, or in car holder, that provides for charging and external/headset sound causes the voice cut-off problem to become a lot worse!
Can anyone else please test this to see if it's the same from them? |
Posted: Fri Feb 01, 2008 7:37 pm Post subject: |
i have been using a powered mount with charger and speaker,not tyred it without but will now to see its better |
Posted: Sat Feb 02, 2008 10:56 am Post subject: |
Have now loaded Garmin XT and have no voice issues!
Must be a TomTom problem - but they are not being very helpful ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) |
Posted: Sat Feb 02, 2008 2:38 pm Post subject: |
as I said my friend has no problem but he has installed tomtom in memory card not main memory may be werth a go |
Posted: Sat Feb 02, 2008 7:31 pm Post subject: |
just installed tomtom and reinstalled to storage card tyred a 20 Miles demo at 250 speed was OK need now to do a real one |
mrg2003 Regular Visitor
Joined: 12/03/2003 18:19:15 Posts: 136 Location: United Kingdom
Posted: Sun Feb 03, 2008 10:20 am Post subject: V1615 |
any tomtom issues look at
http://www.xda-developers.com/
most of the answers are there, including tomtom voice problems.
Mine works fine, standard vodafone rom. |
Posted: Sun Feb 03, 2008 2:45 pm Post subject: |
just tyred a route with my powered mount still have fault then did same route with no powered Mount all OK |
Posted: Mon Feb 04, 2008 12:55 pm Post subject: |
Hi mrg2003, I've been on the xda-developers site a lot - no solution there...
This is a real issue - and the fact Garmin works 100% suggests this is a real TomTom issue... |
Satellite Lifetime Member
![](modules/Forums/images/avatars/184746421647d16abcb1839.gif)
Joined: Apr 18, 2005 Posts: 176 Location: Swansea, UK Napoli, Italia
Posted: Mon Feb 04, 2008 2:57 pm Post subject: |
Hi, I'm having the same problem as Eugene7, but what is strange is that I had my phone since August and only in the last week this is happened.
I have reinstalled the voices, then tried reinstalling TT and also put the voices in main folder of the device, the rest is on SD, still no joy. The only thing I have not reinstalled is the map itself, could that be the problem? |
Posted: Tue Feb 05, 2008 12:23 am Post subject: I tried |
Eugene7 wrote: | Hi mrg2003, I've been on the xda-developers site a lot - no solution there...
Sorry, M8. I tried.
I isntalled mine from the cab file only, as I could not get the CD to work properly. I used tomtom home to update the voices. |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Tue Feb 05, 2008 4:09 am Post subject: |
Satellite wrote: | Hi, I'm having the same problem as Eugene7, but what is strange is that I had my phone since August and only in the last week this is happened. | What have you put on the phone in way of software in the last week?, the other possible fix will be to format the memory card and then re-load everything from scratch and see if that cures the problem - Mike |
Posted: Tue Feb 05, 2008 1:07 pm Post subject: |
Hi Mike, Thanks for your replay. The phone was as i set it up from the start ( I did all the donkey work then ), I say was because I had a full SPB backup of when TT was installed ( I make a backup prior to any software installation ), I hard reset it the device, installed the backup and so far it seems to be working ok. It just goes to show that backups are vital!!!!
Thanks again |
