Pocket GPS World :: View topic - Recommendation for RX 1950
fleurie
PostPosted: Wed Jan 30, 2008 2:03 pm    Post subject: Recommendation for RX 1950 Reply with quote
I have just aquired an Ipaq RX 1950 pda and would like to instal Tom Tom or some other nav software, the pda has wifi but NO bluetooth so am looking for recommendations for a suitable receiver. I shall also have to get an in car mounting of some sort.
Any ideas would be appreciated
philpugh
PostPosted: Wed Mar 05, 2008 10:38 am    Post subject: Reply with quote
The problem you have is that you will need the SD slot on the iPaq for the maps so you will need to check if the unit can accept serial data connections.
There are a few GPS receivers out their that can provide serial data connection. You could always take a look at some of the GPS 'mice' that generally have serial connection.
I used to use a GARMIN GPS36HVS 'mouse' that had a magnetic mount to attach it to the boot of the car. This connected to my iPaq 3630/3660 via a home made serial adapter. It worked extremely well - but I did get fed up with all the wires dangling about.
As for mounting the device I would recommend the BRODIT/PROCLIP mounts - see supplier adverts on RHS of forums (usually).
Phil
