Pocket GPS World :: View topic - SATMAP 10 .MAP FILE
SATMAP 10 .MAP FILE
marksam
PostPosted: Sat Jan 26, 2008 6:32 pm    Post subject: SATMAP 10 .MAP FILE Reply with quote
Can anyone help, I've just purchased a SATMAP 10 and was wondering If i can view a .MAP file as a map or infomation, or do I have to purchase some software to do this
It would be very helpful
mark
robs1972
PostPosted: Sat Jan 26, 2008 6:44 pm    Post subject: Reply with quote
Do you mean the route file called .MAP or the big mapping data file on the SD card called .MAP?
With Satsync...currently in Beta form...the route files called .MAP can be converted to a GPX file when you use it to transfer from the Active 10 to your PC....you can also read that file unconverted in Notepad although it's not nearly as meaningful.
The mapping data file called .MAP cannot be viewed as a map on your PC.
I like mapping, I like mapping, I like mapping and I like to map!
marksam
PostPosted: Sun Jan 27, 2008 4:33 pm    Post subject: Reply with quote
Does the MAP. file automaticly convert or do you have to use some software.
mark
PostPosted: Sun Jan 27, 2008 5:44 pm    Post subject: Reply with quote
You need the SatSYNC software on the PC to convert the file which, as Rob has said is only currently available in Beta test - Mike
Dragsterman
PostPosted: Wed Jan 30, 2008 12:12 pm    Post subject: Reply with quote
How can one get the SatSync software beta version?
23.092 (10 Sep 25)
