Pocket GPS World :: View topic - New install - help needed
Tuts
PostPosted: Fri Apr 23, 2004 9:12 am    Post subject: New install - help needed Reply with quote
I've just done a first time install of TT3 to my ipaq 3630 but when I try to run it I get the message "You need to load a map from the TT Navigator CD". I have loaded a map but to my storage card via the install program because I don't have mauch space left on my ipaq. So why is it complaining ? All I can do is press OK and return to the Today screen.
I have sent a mail to TT support but I thought I might get it sorted faster through this forum.
Steveg
PostPosted: Fri Apr 23, 2004 10:46 am    Post subject: Reply with quote
Hmmm,Don't actually know the answer to this, but if I were in your position I would be very tempted to uninstall the whole thing (including SD card) and re-install afresh, in case these was some minor glitch when installing the first time. If it does the same after a new clean install then there must be some other problem to be investigated.
Sorry I cannot help more
Steve
MrT
PostPosted: Fri Apr 23, 2004 11:46 am    Post subject: Reply with quote
I got this fault when I started TomTom wizard rather than TomTom itself. I would check as I think the icon in your menu calls the wizard until the program has run for the first time. If your icon has a yellow star in one corner, that is the wizard program.
I am not sure if I fixed this by running the main program from file manager or by applying the 3.01 update.
samriley
PostPosted: Fri Apr 23, 2004 12:13 pm    Post subject: Reply with quote
this can be fixed by uninstalling the tomtom wizard, then using the explorer navigate to /Program Files/Navigator <- you then need to rename the Tomtom Navigator.exeo to Tomtom Navigator.exe
Tuts
PostPosted: Fri Apr 23, 2004 2:36 pm    Post subject: Reply with quote
Thanks for the replies, Sam how do I view the files extensions in PPC2002.
PostPosted: Fri Apr 23, 2004 2:46 pm    Post subject: Reply with quote
It's far easier to use explorer on your PC with your PPC docked. You can then see the file extensions.
Tuts
PostPosted: Fri Apr 23, 2004 3:15 pm    Post subject: Reply with quote
Thanks guys you're absolute stars, you beat TT support anyway. I did what Sam suggested renaming via my PC and it works fine.
