cyberbot Regular Visitor
Posted: Sun Jan 13, 2008 11:06 am Post subject: SD Card of 2 GB and MAp V7 |
i have Got SD card of 2GB
Can i install the map 7 Wich are 1.89GB ? in this SD ?
Thanks guys |
Posted: Sun Jan 13, 2008 11:19 am Post subject: |
Did you purchase the map? - Mike |
Posted: Sun Jan 13, 2008 12:30 pm Post subject: |
yes i did and downloaded them
but when i save them in the SD
my tomtom Said Map not found |
Posted: Sun Jan 13, 2008 1:50 pm Post subject: |
Did you use TomTom Home softare on the PC to install the map? this software package deals with map activation, if the device is reporting the "No Map" screen it usually means the map isn't activated - Mike |
Posted: Sun Jan 13, 2008 1:52 pm Post subject: |
Just one other thought though, Have a read of This Thread which details using the clear flash tool set in order to activate a map, it sounds similar to your problem - Mike |
Posted: Sun Jan 13, 2008 2:12 pm Post subject: |
I dont get anything that the map is not activated or something where to writ the activation code
Only Map has not been found that all |
Posted: Sun Jan 13, 2008 2:19 pm Post subject: |
Map activation is handled automaticaly by TomTom Home you don't write anything down or put number in, have you tried the clear flash utility I linked to above? - Mike |
Posted: Sun Jan 13, 2008 2:35 pm Post subject: |
hello mike
thanks for the help
i did tried the Flash but doesnt work
i have reisntalled and its still giving the same problem |
dhn Frequent Visitor
Posted: Sun Jan 13, 2008 4:01 pm Post subject: |
cyberbot wrote: | hello mike
thanks for the help
To be clear, when you say 'reinstalled', you used TTHome to do the installing, you did designate the sd card to install it to and my understanding is that certain models of tomtom require the operating system to be installed on the sd card where the map is located (the 720 I have doesn't have this requirement).
Anyway, things to check. |
Posted: Sun Jan 13, 2008 4:08 pm Post subject: |
thanks for the help
i did called and the problem is fixed
my ID device id was Faut
thanks again |
Andy_P Pocket GPS Moderator
Posted: Mon Jan 14, 2008 2:56 pm Post subject: |
I can't help wondering where this "SD card of v7 maps" came from.... |
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Posted: Mon Jan 14, 2008 3:28 pm Post subject: |
Andy_P2002 wrote: | I can't help wondering where this "SD card of v7 maps" came from.... |
Well the OP says he downloaded the maps, so I assume he has a 2Gb card kicking around on which to put them. Me, I have an 8Gb SDHC card. The maps came from TomTom and the card came from the USA, courtesy of Mike Barratt. ![Laughing](modules/Forums/images/smiles/icon_lol.gif) _________________ Tim |
Posted: Mon Jan 14, 2008 4:08 pm Post subject: |
Humble apologies... I misread the original post. Thought it was an SD card purchased with maps on already. |
