geoffsuitor Occasional Visitor
Posted: Sat Jan 12, 2008 6:54 pm Post subject: Transferring to larger card - Activating maps? |
I have just transferred the files from my existing Go 710 to a new 2GB SD Card. The files seem to have moved over ok, but as I am trying to set up, I am getting a message that the map has not been activated and that should contact TT to get an activation code.
I have tried using the code that was initially supplied with the sytem and I'm now getting the message...."Sorry, this is not the correct activation code for the product Western_Europe"
Am I doing something wrong?
Geoff |
if1977 Lifetime Member
![](modules/Forums/images/avatars/gallery/1_tomtom_x20.jpg)
Posted: Sat Jan 12, 2008 7:06 pm Post subject: |
Yes you are, there is a page at TomTomwhere you type in the product code which you have, then type in the device code that is on your TT then TT give you an activation code. If you give me 10 mi nutes i will get it for you or if someone else knows it thet will post it for you. _________________ NEW Tomtom GO 500 (hope it is good)
iphone (running all day, doesn't like it)
XL LIVE IQ Routes (Got stolen and miss it)
GO 510 (in drawer now, time for upgrade) |
Posted: Sat Jan 12, 2008 7:22 pm Post subject: |
Follow the link below and you should be ok.
http://www.ttcode.com/ _________________ NEW Tomtom GO 500 (hope it is good)
franb Banned
![](https://www.pocketgpsworld.com/images/banned_user.jpg)
Posted: Sun Jan 13, 2008 11:42 am Post subject: |
I would try the Flash tool first, if you have copied the map files in total to the SD card and put them in a folder with the exact name they were in before the device should pick the map up and use it with the same codes as previously used - Mike |
Posted: Sun Jan 13, 2008 12:43 pm Post subject: |
Thanks for the help gents......it worked fine after I ran the flash.
Geoff |
