Oldboy Pocket GPS Moderator
Posted: Wed Jan 02, 2008 7:24 pm Post subject: |
If the OGG Files are present, they are chosen automatically because of the naming. You don't see them. _________________ Richard
Posted: Wed Jan 02, 2008 7:26 pm Post subject: |
Lets check a couple of things here first:
1/ Have you got the PGPSW speed camera database loaded to the new map folder (the version 710 map)
2/ Have you got the 710 map set as the active map, check this by tapping the sat strength meter followed by the version box on the next screen, if its not the 710 map use Change Preferences/ Map Preferences/ Switch Map to select the 710 map.
3/ In the 710 map folder have you got a full set of ogg files?
Once the above is done go to Change Preferences/ Manage POI/ Warn When Near POI and select the first PGPSW speed camera in the list, configure the warnings, when you get the four option screen to select the type of warning, make sure you select Sound Effect, then answer Yes to the next question - Mike |
Posted: Wed Jan 02, 2008 7:35 pm Post subject: |
mikealder wrote: | Once the above is done go to Change Preferences/ Manage POI/ Warn When Near POI and select the first PGPSW speed camera in the list, configure the warnings, when you get the four option screen to select the type of warning, make sure you select Sound Effect, then answer Yes to the next question - Mike | He won't have that Mike, as the 700 doesn't have TTS. _________________ Richard
Bill11 Occasional Visitor
Posted: Sat Jan 05, 2008 12:03 pm Post subject: |
Thanks again folks got it working following Andy_P instructions
Also managed to get the First Aid help files downloaded as well
Bill |
Andy_P Pocket GPS Moderator
Posted: Sat Jan 05, 2008 6:34 pm Post subject: |
Yay!! |
shakatar Occasional Visitor
Posted: Sun Jan 13, 2008 12:31 am Post subject: |
does this ogg file method work in the new tt go 920? |
if1977 Lifetime Member
Posted: Sun Jan 13, 2008 12:34 am Post subject: |
shakatar wrote: | does this ogg file method work in the new tt go 920? |
They certainly do. Do you know how to download and apply them. _________________ NEW Tomtom GO 500 (hope it is good)
iphone (running all day, doesn't like it)
XL LIVE IQ Routes (Got stolen and miss it)
GO 510 (in drawer now, time for upgrade) |
Posted: Sun Jan 13, 2008 12:46 am Post subject: |
not reall i dont think,
i tried with my nav 6 but can't get it to work,for eg i have a poi named Zoo sub,United Kingdom.ov2 so i created a ogg file name exactly the same but with .ogg but i still get the bells etc option come up when choosing the alert sound.
also do the ogg files only work with this sites safety cameras do they work with the tom tom safety cameras also?
cheers |
Posted: Sun Jan 13, 2008 12:53 am Post subject: |
shakatar wrote: | not reall i dont think,
cheers |
They only work with the PGPS speed cameras as the name is the same as the cameras but with .ogg at the end. There is also a set made up to go with some of the POI's on this site also. Have a look here and see how you get on.
Edit MikeB to fix link _________________ NEW Tomtom GO 500 (hope it is good)
Posted: Sun Jan 13, 2008 12:58 am Post subject: |
cheers
i clicked the link but it said requested page not found? |
JockTamsonsBairn Lifetime Member
Posted: Sun Jan 13, 2008 1:03 am Post subject: |
shakatar wrote: | cheers
i clicked the link but it said requested page not found? | Try this _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Sun Jan 13, 2008 7:50 am Post subject: |
shakatar wrote: | so i created a ogg file name exactly the same but with .ogg but i still get the bells etc option come up when choosing the alert sound. | Is it an ogg file that the TT can use? There is only only one ogg format that it can handle.
Can you go through how you created, and named, the File? It might give us a clue. _________________ Richard
Posted: Sun Jan 13, 2008 11:52 am Post subject: |
ive tried two ways,i created a message with the text to speech link,saved it then converted it to ogg using the switch convertor program,copied and pasted into my map folder and renamed it to match my poi but put .ogg on the end.
for eg my zoo poi says zoo sub,united kingdom .ov2 so i renamed ogg file to match eg zoo sub, united kingdom .ogg
i tried the ones from this site to go with the pois from this site but my pois are nearly all named like my zoo poi with the wording sub, united kingdom not a straight zoo.ov2
the one for tesco did work my poi says tesco.ov2 and the voice file from here says tesco.ogg so i put it straight into my map folder and that did work. |
Posted: Sun Jan 13, 2008 3:37 pm Post subject: |
shakatar wrote: | i for eg my zoo poi says zoo sub,united kingdom .ov2 so i renamed ogg file to match eg zoo sub, united kingdom .ogg
i tried the ones from this site to go with the pois from this site but my pois are nearly all named like my zoo poi with the wording sub, united kingdom not a straight zoo.ov2 | When you download POIs.zip, do you Unzip the contents to your Hard Drive? When I do I get zoo.ov2 and zoo.bmp.
If you convert an audio file to an ogg file it will usually add the ogg extension. You don't need to.
Unless you can see the File extensions in Explorer, be very careful about adding more. e.g. zoo.ogg.ogg, because it won't work. _________________ Richard
Posted: Sun Jan 13, 2008 10:49 pm Post subject: |
do i need to remove all the orginal tomtom safety cameras and other orginal tomtom poi's from my device and only use the ones from this site to get it to work?
thanks |
