Pocket GPS World :: View topic - Issues upgrading 300 - "Internal Server Error"
Tumbleweed
PostPosted: Fri Jan 04, 2008 10:07 am    Post subject: Issues upgrading 300 - "Internal Server Error" Reply with quote
I have raised a problem with TT and waiting for a response but thought I'd see if anyone else had had this.
Installed Home 2.1, upgrade to latest TT software as recommended by it (7.162), bought map on TT site, then via Home start the process of downloading, which seems to work, in that it apparently downloads the file, gets to 0 seconds remaining (though there is a little bit of the download bar that doesn't fill in), then there is a wait of a few seconds and I get 'internal server error'.
FWIW I can see the new downloaded map on my HD, in fact there are many copies, presumably after each download has stopped (I have tried this several times, as you do :-). One of the downloaded files in each folder 'activationmap_50028.cab is 0kb, that doesn't look good? All the others seem ok, the map is 129,664kb.
Any ideas?Is there an easy way to put the map of these on my TT directly and have it work? I'm guessing I need this activationmap file to have something in it?
PostPosted: Fri Jan 04, 2008 10:57 am    Post subject: Reply with quote
Are all the Activation_Map Files 0KB? Should be 1KB.
As it's names implies it holds the Map Activation File, so you could install the Map but not use it.
It might be quicker to telephone TT and say that the activation has downloaded as a Zero Byte File. 0845 1610009
Tumbleweed
PostPosted: Fri Jan 04, 2008 12:25 pm    Post subject: Reply with quote
Thanks oldboy did that, they advised me to delete the stuff that was downloaded and go through teh download again, and that did the trick.
Looks like I have got some new features to play with now (trip logging?), must also sign up for and download the new speed cams here mine are more than a year out of date!
23.054 (28 May 25)
