iffy Occasional Visitor
Posted: Tue Apr 13, 2004 4:27 pm Post subject: pretec compactGPS failed |
Has anyone else had problems with compactGPS? Mine failed after 10 months (10 months ago) and I have not yet received a replacement.
It was bought from Expansys, who denied all knowledge of the sale, and referred me to the manufacturer. No luck there.
The fault appears to be on the satellite detection side- tested with Winfast Navigator- and all satellites which appear are shown at the same azimuth and bearing- zero in both cases. The GPS cannot therefore determine my position.
I am hoping that this symptom is simply a failed antenna, and can be 'worked around' by plugging in an external antenna. Does anyone know for sure? I would rather not waste money buying something which may well follow the GPS into the bin.
PS have contacted Expansys again and there may be a chance of replacement. Is this a record? (10 months from complaint) |
Dave Frequent Visitor
![](modules/Forums/images/avatars/92698813943397cac09a13.gif)
Posted: Thu Apr 15, 2004 1:23 pm Post subject: |
You may find the backup battery has drained and isn't keeping the almanac. Try keeping it running outside for 15 mins and see if it will obtain a factory fix. |
bilko Occasional Visitor
Joined: 25/05/2003 23:44:24 Posts: 15 Location: United Kingdom
Posted: Fri Jul 16, 2004 4:01 pm Post subject: |
So how do you replace the backup battery if it needs changing? I have ahad a peek inside my Pretec CF and it seems to be soldered onto the board. _________________ Bilko |
Posted: Sat Jul 17, 2004 3:38 pm Post subject: |
There is no easy way of changing this. Some do have a physical battery on-board, most more modern GPS Receivers have a capacitor that retains a charge that keeps the almanac data stored in chip.
The only way to re-generate this is to charge it for around 12 hours, but if it's not holding a charge, there's very little you can do. |
