epoch Occasional Visitor
Posted: Fri Dec 07, 2007 3:36 pm Post subject: "Not enough space" when downloading new map |
Hi all.
So finally TomTom make the 7.10 maps available for my Go 720 (thanks to a very helpful 'John G' at TomTom - by far the most helpful I've encountered).
The map appears in my update list.
However, when I click on it to download I get a message saying "Not enough space on device".
The download is 1.8GB.
What's the best approach to this? I've already made a complete backup copy of the Go, just in case (seperate from Home's backup).
I assume I'll need to delete something, but what? And if there's a problem with those maps, can I just copy my backup back onto the TomTom ?
Thanks in advance. |
LesMiserable Occasional Visitor
Posted: Fri Dec 07, 2007 3:42 pm Post subject: |
Best to buy a 2 Gig SD card, then transfer all your existing data over then download the neweer map onto it. _________________ TT 500
Map: V855.2931UK & Ireland
Version 7.903(9183/081025) OS:2344
GPS v1.21 Boot 5.5022
TT Home v 2.7.6.2056 |
xda Lifetime Member
Posted: Fri Dec 07, 2007 4:18 pm Post subject: Re: "Not enough space" when downloading new map |
epoch wrote: | Hi all.
I did a complete backup first using copying the contents to a folder on my "D" drive. Then from within Home deleted the Western Europe maps. Downloaded the update and let it install. Home2 then put the PGPSW camersa back on etc. Job done. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Andy_P Pocket GPS Moderator
Posted: Fri Dec 07, 2007 6:44 pm Post subject: |
LesMiserable wrote: | Best to buy a 2 Gig SD card, then transfer all your existing data over then download the newer map onto it. |
That ain't going to work unless you delete the old Western Europe map off it. There's not enough room for both. Which puts you in the same situation of having to transfer all your POIs etc across. So there's no point in buying a new SD card.
xda's technique is fine. |
dhn Frequent Visitor
Posted: Fri Dec 07, 2007 7:02 pm Post subject: |
Andy_P2002 wrote: | LesMiserable wrote: | Best to buy a 2 Gig SD card, then transfer all your existing data over then download the newer map onto it. |
Andy, a week or so ago, when I tried to dl the North America 7.10 map to my tom tom 720 with no sd card, I was confronted with a lack of space issue. Using Home software 2.1, I removed the existing map folder from the unit. Home wouldn't let me dl the map, not enough space. So, I removed voices, still the complaint. Kept stripping and stripping till home stopped complaining. Let me download.
Well, 2 days later it seemed (actually 4 hours +), the new map did dl and, after 15 minutes into the install routine, the bloody software complained AGAIN about not enough space (-23 mb) on the unit!!
Then, the "fun" began as I had to go into the map zip file and strip a variety of cspeech_state. dat files to get the zip file small enough to install. I also found out that, for me anyway, just extracting the files & folders in the zip file to my hard drive and copying them to the unit wouldn't work as the unit complained "No maps found" when I turned it on.
I guess it is the act of installing via home software that generates a current mapsettings.cfg file for the unit to read. Even copying over my .cfg file from my backed up NA map 7.05 didn't 'take'.
What was most frustrating in the entire process was the fact that initially tomtom home software 'read' that there was enough space to download the map and then later the same software complained there wasn't enough space.
I can see a SD card in my future. |
franb Banned
Posted: Fri Dec 07, 2007 7:04 pm Post subject: |
When I (finally) got & d/loaded my "Latest Map Guarantee" v710 Euro map (albeit the smaller version) it overwrote various files in the Euro map folder & root. It didn't say there's no room (which there obvioualy was plenty of) or to delete/remove previous version first.
That's using TTHome & LMG, maybe it's different if you BUY a later map? |
Posted: Fri Dec 07, 2007 7:12 pm Post subject: |
That's what it sounds like.
Normally when you BUY a map (even of the same territory), it downloads into a new folder leaving the old one intact.
Various people have recently been saying that they were suprised to find that their POIs were still intact on a new map. Now, that implies that either Home is being clever and copying them all across from one folder to another, OR that it is no longer making a new map folder, but is overwriting data in your existing one. No-one who's said that has reported back what exactly WAS going on though. |
xda Lifetime Member
Posted: Sat Dec 08, 2007 5:17 am Post subject: |
See my previous post where I said that after the update the POI files previously installed were still intact.
When the new map was available to download in Home 2 it said there was not enough room and needed to have space created on the device.
I selected to delete the Western European Map which Home 2 did, and it started downloading the new one.
What I failed to do was open My Computer and take a look at the "T" drive which is the TomTom Go720 internal storage when docked to the PC to see just what it deleted.
During the install it shows what files are being installed, the last ones were all the PocketGPSWorld Camera files and some but not all of my own POI's. It also retained the additional downloaded TomTom gbr_doctor.inf and .ov2 files.
All the previous MapShare files CA****.ov2 & PA****.ov2 had gone.
There was no evidence of a new Western Europe folder being created but it gave the impression that it had only deleted the TomTom files that it was going to replace or overwrite within the map folder.
After the install I did have to re-setup all the POI warnings, re-do some of the map corrections.
I might do this update again when I get back from Alton this weekend to see just what it is deleting prior to the update downloading. _________________ Graham.
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Sat Dec 08, 2007 7:58 am Post subject: |
xda wrote: | There was no evidence of a new Western Europe folder being created but it gave the impression that it had only deleted the TomTom files that it was going to replace or overwrite within the map folder. | This was my experience. The only difference was I didn't need to delete anything because I had sufficient space. _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
mediafriendly Regular Visitor
Posted: Sat Dec 08, 2007 10:33 am Post subject: |
Andy_P2002 wrote: | That's what it sounds like.
I think Home is being clever. When TomTom finally updated my Home with the latest 7.10 UK map, I left the previous 6.75 map on the device and installed the new one. When I installed 7.10, my speed cameras, voices, Vicki etc were copied over automatically. |
xda Lifetime Member
Posted: Sat Dec 08, 2007 10:35 am Post subject: |
That's the difference between a 4GB hard drive and 2GB flash memory. With everything installed only have about 120MB free.
I suppose I could have installed to the 4GB SD Card but would have had to delete 3.5GB's of MP3's and Photos etc. _________________ Graham.
Posted: Fri Dec 21, 2007 5:42 pm Post subject: |
Grrrr!
The map download is 1988MB.
I tried removing the Western Europe and Canary Isles maps from the TomTom and TTHome still says there's not enough space.
So, I got a 2GB SD card. But stupid "IT Professional" me forgot to consider that a 2GB card is only about 1.91GB formatted. So - not enough room there either.
I really don't want to go buy a 4GB SD card.
Is there anything on the TomTom I can safely remove (as well as the maps)?
furryfred Regular Visitor
Joined: Dec 15, 2005 Posts: 131 Location: here and there - and possibly somewhere else
Posted: Fri Dec 21, 2007 6:47 pm Post subject: |
I haven't doen this on my 700 as yet because I got the same message about space.
When it downloads what name does it give the map file?
Is it possible to download it onto the computer and then, if it is the same name just drag the contents onto the old map folder? This would keep all the pois and ogg.files whilst updating the rest of the files - assuming that they all have he same names!
The alternative would seem to be to drag the pois etc into the new file?
But I may be talking through my hat! _________________ Furry Fred
(a very very nice, handsome and generous gentleman who is really rather modest, shy and retiring!)
They didn't make many like him - and now they've lost the mould! |
Posted: Fri Dec 21, 2007 6:53 pm Post subject: |
HOME doesn't give you the Option of Installing to another location. Unlike the pre-HOME Installation method. _________________ Richard
Posted: Fri Dec 21, 2007 7:51 pm Post subject: |
I've had a good look through the TomTom filesystem and the only thing I could see which warranted removal was some audio book demos. Even with them, and the WE and Canary Islands maps gone, there was still nowhere near enough space.
Looks like a 4GB SD card is the only option. They're cheap enough, but it's still bloody annoying that TomTom release an update that won't even fit on the target device. |
