Gee-Pee Lifetime Member
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Sat Nov 24, 2007 9:27 am Post subject: Removal of Subscription Safety Cam POIs from N20 |
I'm having difficulty in removing the Navman installed safety cameras from my N20. In SmartST Desktop - Manage POIs they don't appear - only the PGPSW installed ones.
Anyone got a simple way of doing it, please _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
Posted: Sat Nov 24, 2007 10:58 am Post subject: |
I had to remove some of the PGPSW camera files to get below a certain number of custom POI files on the F20, once you can see them simply de-select them then add the PGPSW cameras back on to the device - I had to remove two files, but I didn't have pMobiles installed - not too sure the N20 will beave in the same way but it is worth checking - Mike |
Posted: Sat Nov 24, 2007 11:05 am Post subject: |
mikealder wrote: | I had to remove some of the PGPSW camera files to get below a certain number of custom POI files on the F20, once you can see them simply de-select them then add the PGPSW cameras back on to the device - I had to remove two files, but I didn't have pMobiles installed - not too sure the N20 will beave in the same way but it is worth checking - Mike |
I'll give that a try, Mike but suspect it may not work I've had a look at the files on the unit via MS Active Synch -- Explore, but cannot ID the appropriate files. The reason I need to do this is not to make space - I have plenty, but I'm off to Switzerland at Christmas and I must make sure that there are no Swiss cameras on the device as they are illegal in that country - on pain of having your GPS confiscated and destroyed.
Graham _________________ Gee-Pee
TheM Frequent Visitor
Posted: Sun Nov 25, 2007 8:33 pm Post subject: |
Gee-Pee wrote: | I'm off to Switzerland at Christmas and I must make sure that there are no Swiss cameras on the device as they are illegal in that country - on pain of having your GPS confiscated and destroyed. |
Navman does not provide safety camera subscriptions for countries where it is illegal to have such information (e.g. Switzerland and Germany).
Are you worried that you could have your device confiscated if you have safety camera information for other countries on it? |
Posted: Sun Nov 25, 2007 9:27 pm Post subject: |
TheM wrote: | Gee-Pee wrote: | I'm off to Switzerland at Christmas and I must make sure that there are no Swiss cameras on the device as they are illegal in that country - on pain of having your GPS confiscated and destroyed. |
Are you worried that you could have your device confiscated if you have safety camera information for other countries on it? | No, I just assumed that there would be safety cameras on there My son has a Mio and he did have some which he removed, but then he lives in Switzerland. Thanks for the info. _________________ Gee-Pee
