Pocket GPS World :: View topic - Custom POI with CoPilot Live 7
juzzman
PostPosted: Fri Nov 23, 2007 3:19 am    Post subject: Custom POI with CoPilot Live 7 Reply with quote
This is a pretty basic question, so apologies if I am missing something. I have just installed the files for safety cameras in Australia. I now want to install what I assume would be called a custom POI, which is school zones. In Australia the speed limits come down dramatically in these areas.
My issue is, I am unsure how to do this as I am not sure whether it will screw up my safety cams or whether there is a different process. I have the files (*.ov2, *.bmp).
Any suggestions would be appreciated.
Justin
PostPosted: Fri Nov 23, 2007 10:00 am    Post subject: Reply with quote
for the european version you just copy ov2 files into the eu/save folder so i presume you would do the same with the equivalent aussie map?
out of curiosity, do you use our camera database? this has lots of the variable speed cameras near school zones so you'd get a warning that way.
juzzman
PostPosted: Sun Nov 25, 2007 12:28 am    Post subject: Reply with quote
thanks for describing what i need to do. I have done the same with safety cams but didn't know if doing such again would stuff up the cameras. I am using a database file from http://www.ozpoi.com/
I didn't know you had files for Australia when I did this.
22.055 (29 May 24)
