Pocket GPS World :: View topic - Nuvi 6XX Firmware update - 4.20
BAVC10
PostPosted: Tue Nov 13, 2007 11:15 pm    Post subject: Nuvi 6XX Firmware update - 4.20 Reply with quote
Garmin have just released 4.20.
Upgrade looks worth doing if it actually does make the map refresh quicker.
Changes made from version 4.10 to 4.20:
Improved the map drawing speed.
Corrected issue with proximity points in areas with many roads causing the map to draw slower.
Corrected issue where all traffic delays were represented as 1 minute.
philpugh
PostPosted: Fri Nov 16, 2007 10:00 am    Post subject: Reply with quote
Seems to be a bit crisper redrawing maps. Also - and this has only been checked on a short journey into work this am - the lag when not following a route doesn't seem as bad as it can do - but need to try it over a longer drive to be sure.
Phil
swing
PostPosted: Fri Nov 16, 2007 12:37 pm    Post subject: Reply with quote
I've heard rumours that a reset of the device can speed things up too - so it might be that the firmware update naturally resets the device, which could explain the speed up. I guess the interesting point is to see if it remains faster after a few weeks...
Please don't be offended if I do not reply to a PM - please ask questions via the forums.
BAVC10
PostPosted: Mon Nov 19, 2007 8:59 am    Post subject: Reply with quote
Firmware 4.20 seems to be pretty stable and has definitely speeded up the map refresh rate as well as making the zoming in at junctions a bit more logical.
Only slight bug seems to be when you tap the "next turn" box it doesn't always display your next turn (just the full map screen)..
madhatter
PostPosted: Tue Nov 20, 2007 7:15 pm    Post subject: Reply with quote
If you listen to mp3's and have the pocket gps speedcamera database with mp3 voice files the 4.20 update will cause problems. It causes the mp3 to skip to the next track when the voice speedwarning goes off. Garmin are looking for another firmware update and have said they may pull the 4.20 update.
23.052 (14 May 25)
