Pocket GPS World :: View topic - TT510 upgraded to 7.160 now POI corruption
Goto page Previous  1, 2
ducati748
PostPosted: Wed Nov 14, 2007 8:59 pm    Post subject: Reply with quote
BodgerBaz wrote:
Milesey wrote:
Looks like the latest version is being messed up by the .INF files that POIedit produces alongside the OV2 and BMP files. I've deleted the .INFs and all seems fine
Oh thank you Milesey. That was exactly the problem. I've deleted mine and all is working as it should. That would explain it as it was only the POIs downloaded from POIedit that were affected.
Many thanks for spotting that one - much appreciated Wink
could someone give me some pointers were to find these files as i also have my speed cams messed up, all are usings ogg file sounds but only some are messed up and others are ok, tried reloading them again and they are still the same any help would be greatfully recieved.
thanks
freddo
PostPosted: Sun Nov 18, 2007 9:21 am    Post subject: Reply with quote
look in g.britain map and delete icons with a notepad and gearwheel these are information files.once deleted everthing should be ok.
any pio conected to these files will be c messed up
hope this helps
PostPosted: Sun Nov 18, 2007 1:55 pm    Post subject: Reply with quote
hope this helps
A bit dangerous this...
The icons shown next too any file in Windows can change completely, depending what programs you have "associated" with each file type. For example I don't have ANY files with a gearwheel.
The only safe way is to describe the FULL filename including the three letter extension (.txt for text files, .exe for programs etc. - those are just examples, DON'T delete them!)
If you cannot see those extensions, you need to enable the correct view in Windows Explorer or My Computer:
Go to the 'Tools' Menu,
Select 'Folder Options'
Select the 'View' tab
Scroll down the list of entries and UN-tick "Hide extensions for known file types"
(While you are there, you can TICK 'Show hidden files and folders" too. This will let you see EVERYTHING on your TomTom's storage).
Page 2 of 2
23.054 (28 May 25)
